Greasy Tree , the best darn three peice band around these area's anywayI have to ask....name of the band. I only know the Beach Boys...haha
Good morning, pleasant day to go for a drive around Sarasota, meeting my little brother (40) for dinner. Yesterday driving down, the Fury wanted to go faster than I did.
It's Karl.The axle in my 68 Formula S was built by Dvorak Machine...
dont know. your envelope went out today! It is tracked but doesn't require a signatureGentlemen, 'morning...who has the revel Stokes for my coffee?
Some of the drills need to be cleaned, the triggers, and battery connections. BUT they all worked when I quit using them. all the batt. I gave you are good. Hold trigger down while installing the battery, you will see what I mean....about the battery connections..@Mopar Tim I did check ,boxes did come in. Didnt have time to open them up this morning but they are here
yeah, im gonna take them along with me this weekend, give me something to do saturday night.Some of the drills need to be cleaned, the triggers, and battery connections. BUT they all worked when I quit using them. all the batt. I gave you are good. Hold trigger down while installing the battery, you will see what I mean....about the battery connections..
Disassemble it and move it in pieces...re-assemble on site.So I need suggestions: I have a 12 ft wide, 16 foot long, 11 foot tall storage shed. Sits on 4, 4x6 treated runners, with 2x6 purlings with 1/2in OSB for the floors. Metal sided, shingled roof. I need to move it about 3 miles to my property. It's too wide for any trailer I have access too, too heavy to set on a wagon with the tractor, how do i move it? Ive thought about jacking it up, putting two ash trees under it and dragging it along the road all the way there. Problem is, the road is curvy and hilly. and while not the busiest road, it does have traffic, a couple cars or so every few minutes. by tractor, its about a 10-15 minute drive. Other option is, since I built it in stages, the walls and roof and then the floor, it could be taken apart and transported that way. this step would be the most difficult and time consuming but ultimately the safest.
That's probably gonna be the route I go. I'll probably go ahead and replaced the floor and walk in door as well. We put a used door on it to cut cost and the seals went bad, it leaked and rotted the floor under the door. Guess it gives me a good excuse to do it lolDisassemble it and move it in pieces...re-assemble on site.
Call a local towing company. They can pull it onto the bed of their rollback and drive away. Back up to where you want it, tilt the bed till it makes ground contact and drive away. They probably won't charge much more than a regular tow.So I need suggestions: I have a 12 ft wide, 16 foot long, 11 foot tall storage shed. Sits on 4, 4x6 treated runners, with 2x6 purlings with 1/2in OSB for the floors. Metal sided, shingled roof. I need to move it about 3 miles to my property. It's too wide for any trailer I have access too, too heavy to set on a wagon with the tractor, how do i move it? Ive thought about jacking it up, putting two ash trees under it and dragging it along the road all the way there. Problem is, the road is curvy and hilly. and while not the busiest road, it does have traffic, a couple cars or so every few minutes. by tractor, its about a 10-15 minute drive. Other option is, since I built it in stages, the walls and roof and then the floor, it could be taken apart and transported that way. this step would be the most difficult and time consuming but ultimately the safest.
LoadingCall a local towing company. They can pull it onto the bed of their rollback and drive away. Back up to where you want it, tilt the bed till it makes ground contact and drive away. They probably won't charge much more than a regular tow.
Yes to do it lawfully.12 feet wide!!!! Come on guys!!! That is a permit load.
And sometime the law is there for a reason. I dont know what the road are like where he needs to move it, but any traffic and he is SCREWED!Yes to do it lawfully.
And your "free" shed cost you a lot of money.Agreed. Just about the time you move it at night someone comes along and your shed shears the roof off their car. I didn't pay attention to the dimensions in the first post. A permit would be the right thing but then there's pilot cars, moving power lines etc. Disassembly is looking like a better option.
Loading
Unloading
With some 2x4's you could probably make it so you could bolt it back together. Would require some thought but it could be done...IMO, without seeing the shed....It's too tall for a roll back. I have 16 feet under the power lines . The 4 feet of a roll back puts it right at 16 feet. Too close for that. Plus it's too wide. I think tim is right, take it apart in stages. Probably be able to take it apart and move it in one day
