Stop in for a cup of coffee
That is cool for sure if those walls could speak!
Built around 1880.
This is where that Amtrack train flipped the other year.
Check out the elevator.
And if he's pumping 2+ year old gas through it, he's hurting more than helping.
my brother bought my neighbor's dad's car after it sat for over 6 years.... we figured we would have to drop the tank and drain the fuel system....
He put a battery in it, it fired up and he drove it away... Never changed the tank....
Try it first...
I would just ghive it a fast once over look, brake and fuel lines etc, just a fast once over.
Yea. Just make sure the brakes work or better yet have some chocks in position. The one thing that makes that car really nice is how good the body is - don't want t o mess that up
THAT'S WHAT I KEPT ASKING!! And just adjust the distributer???
Put a piston stop in #1 cylinder and find TDC... then check the balancer marks to see if they are at 0° on the timing chain marks... If it is, then it hasn't jumped the timing chain, it's a distributor issue...
If it's not at 0° +/- 2° then check the timing chain and replace with a true roller double roller...
Try it first...
Put on a new fuel filter. After driving it a week or so pull the filter and pour the gas out into a bowl or cup. If it's clear, good to go. If it's orange with sediment, you have fuel system rust issues.
LOL thought you wanted it. No the truck is tuned right now to factory, just want a bit more MPG 10 sucks if I can get it up to 15 I would be happy. What mp you want sb?
If you need a good intake for the truck, I may have a spare SP2P... It's a great low and mid range intake that is perfect for a truck...
