Why are you up so early Z Man ?
I never do either usually 6-7 and I'm fine. Once in a while though get a night like this.I can't sleep more then 8 hours I guess.. I water my garden first thing, ah... and it's nice and quit this time of day
No idea....going to go try for a power nap and let you get back to the morning chores. Check in later.Why are you up so early Z Man ?
Hope you get a good one in and have a dandy day sirNo idea....going to go try for a power nap and let you get back to the morning chores. Check in later.
58 Fahrenheit at 3 am ,on the west coast ,Me Mike...Still dark out side here on the hill, 75 degrees already good morning TJ
She is moving forward hood is ready for paint and fire wall.. I found a hell of a deal on a 5 ton a/c Heat pump for the shop and it has kept me busy $500 for it !!58 Fahrenheit at 3 am ,on the west coast ,Me Mike...
How's the shop build, going..? And ... how's ,"Victoria "....?
Maytag this time..slightly longer than the warranty.
what brand?
Yep, you rememberedSo that was your little addition to shop?
Nice.
... Good morning BenMaytag this time..
MorningMorning!
Old, as in that cement block in the bottom of the washer?Good morning guys. i will have the pleasure of getting rid of the old washer and dryer today. Should be fun.
I use to rob the motor out of washers for fan's like windo fans and such, I wonder what they look like these day, they was strong and would pull a good size bladeGood morning guys. i will have the pleasure of getting rid of the old washer and dryer today. Should be fun.
I'm sure the new stuff is all plastic crap.I use to rob the motor out of washers for fan's like windo fans and such, I wonder what they look like these day, they was strong and would pull a good size blade
I have a buddy that does HVAC work. Got a big squirrel cage fan from a home AC unit. Those puppies will push some air.I use to rob the motor out of washers for fan's like windo fans and such, I wonder what they look like these day, they was strong and would pull a good size blade
