Morning guys
about time you woke upMorning guys
I am going to look these guys up, never herd them , or maybe I have and forgot , thanks
I built mine 32X42, and I used a heat pump system with LPG back up heat. I have one long Duct in the ceiling with 8 outlets. I like the system because, I turn it down to 50, in winter when I leave at night. When I come back in the morning, I turn it up to 65-68, then The LPG gas lights, and gets it up to temp, pretty quick. When it gets within 2 deg of my setting, the heat pump takes over and keeps the temp. I have AC also in that system, but it is rarely used. My building is partially in the ground and shaded by large trees. I just run the 4 ceiling fans in the summer, unless its over 100 outside..My new garage will have ac/heat.
Being a small one, 30x40, it will have one of those split electric ac/heat units.
Not as long as these ones...Just bought a new washer and dryer. first time ever to have a matched set. I'm curious to see how long they last.
Just between here and Memphis, just got off a 5 week tour in spain and other countries over there, thanks for askingSpeaking of bands, what's your son up to?? On the road??
And look at all that eye candy I bet you like that overhead door , nice unitsView attachment 1715186609 View attachment 1715186610 View attachment 1715186611 View attachment 1715186612 View attachment 1715186613
I got pounced by mine. LOLMorning.
Dog wanted out, so i get up.
Expecting that for a high temp todayStill dark out side here on the hill, 75 degrees already good morning TJ
I usually buy from someone with free or cheep haul-away service.Good morning guys. i will have the pleasure of getting rid of the old washer and dryer today. Should be fun.
I rebuilt my washer recently. LG Tromm. It's direct drive and the rotor mounts to the back of the plastic tub. The outside of the motor is a hub that attaches to the shaft of the inner stainless steel tub. The thing that fails is the tub bearings which are also the motor bearing. Leaks through the bearings, out the back and down over the coil. Anyway, motor is useless pile of junk when separated from the machine. Not mine, but similar to this:I use to rob the motor out of washers for fan's like windo fans and such, I wonder what they look like these day, they was strong and would pull a good size blade
What??Hey all.....Good morning...FINELY getting started on my NEW Garage/ Shop!!! Clearing out space to get some measurements...
Nope........Everyone is getting new shops!!
I REALLY need a garage. The shop part I already have.....What??
Coming from the guy that doesent intend on building any more mopars?
I think you contradicted yourself,Tim...
Well STARTING on a Garage is not the same as GETTING a Garage. I might run into code issues....2 Garages on the same property.Everyone is getting new shops!!
go figure, only California would have a law such as that on the booksWell STARTING on a Garage is not the same as GETTING a Garage. I might run into code issues....2 Garages on the same property.
SD County get's their permit fees, you could build a theme park about gnomes back there and they wouldn't careWell STARTING on a Garage is not the same as GETTING a Garage. I might run into code issues....2 Garages on the same property.
wowSo 1 of my concrete customers/contractor shows up at my office door one day. "You know that job I did up in Lakeview?
I traded the job for this.
You think it was worth my time?"
'68 XR7, 4bbl 390, C6. Outstanding condition.
"Yeah, I think you did all right."
Sell it?So 1 of my concrete customers/contractor shows up at my office door one day. "You know that job I did up in Lakeview?
Mine is as well, and Zoned for Horses. But my neighbor is against any thing like that, AND she is a millionaire and has the ear of the building Dept.My property is zoned agricultural, i can plunk a building anywhere i want. Within reason.
