almost the same process they use for chrome, but way easier no dangerous fumes and chemicals to deal with.
YepMark are you running a fitech?
YepTemp gauge is easy what was the other oil?
I don't know anything about them at all. Have to call @Johnny Mac I guess. Have another question for him also.There is a lot of good info on FB. A couple of pages that are dedicated to FiTech tuning. From what I’ve read the petronixs and factory Mopar distributors are hit and miss and often problematic w/timing control.
Temp sensor pull out use a om hm meter check it cold should be around 70 ohms Then put it in a boiling hot cup of water should go up to around 10 is max. Oil take the unit and use your air compresser and some fittings to attach it. No pressure 70 with pressure it will change. Best I can tell you. Might have the ohms backwards let me check.
Definitely not good, once the base timing is set and synced with the unit, the unit has no clue as to what the distributor does. FiTech controls when the coil fires. That’s why the dist needs to be locked and set right from the start. Installation issues are the #1 problem with these units. Most folks blame FiTech when it’s actually installation.It is he has been running it. His issue is it is bogging down mid range. Prob screwing with the control box since it is advancing.
ThanksTemp sensor pull out use a om hm meter check it cold should be around 23 ohms Then put it in a boiling hot cup of water should go up to around 70 is max. Oil take the unit and use your air compresser and some fittings to attach it. No pressure 23 with pressure it will change. Best I can tell you. Might have the ohms backwards let me check.
