I'm with Memike and wish all the vets a happy veterans day...
Or is it a Hoppy veterans day....
10 is nothing, surprised it gets above 2k RPMWe may have you do a distributor for the younger kid's new Barracuda... We are still looking into it and trying to tune it better... It looks like the distributor in it now only has 10° of advance in it... It's set at 10° initial and 20° total and I think it needs more advance.... It has a mild cam and I don't think it needs to run so much advance... If I set it to 34° total, it will be at 24° initial, which I think is too much for that engine...
I will get with you when we have some time to look into it more and figure out what we want...
It is getting 24 1/2" Hg at idle when warmed up... So the cam is not to radical... Will be good for cruising and economy...
Same here, roots and rocks, to limbs with 400 oaks on a hill makes for some fun mowing KarlI use the small regular mower as the two yards that I mow have many hazards and I usually break one per year... Running the cheaper ones helps keep the cost down when I bend the cranks... (They don't cover bent cranks under warranty - manufacturers or extended.... I tried...)
I have 3 mowers for parts... One was only 3 weeks old when I bent that crank... I save them for other parts that I may need, like carburetor and self propelled drive unit...
I hate when that happens.I made a big mug of coffee this morning and when I poured the sugar in from an old diner sugar bottle, the top came off and I dumped 1/4 of the bottle into the cup. Bummer.
Hey any chance you have any blown control boxes? Looking for a few more.
Good morning FABO and veterans!
Tried that concept once as a kid to correct mistaking the cinammon for chocolate making a float.Then make more coffee and add to the sugar until it's the proper mixture for you....
I sure love the new tires you put on it this year, hope mother nature throws a warm front to you and us soonNo started snowing, 1/2 in. Probably have to trailer it or leave it there till spring. Would free up space for another projector
I concluded it was impossible to dilute cinammon, no matter how many times I drank half the glass and added more milk.
I knew what you was thinking about doing from the get go, I have seen them dun that way before (Y) Good luck and I may have to buy one from you when you get the proto types dunWant to gut them here is a clue why
Doing it a bit different for high revs. Have to platy with it on the distributor machine to make sure it works out.I knew what you was thinking about doing from the get go, I have seen them dun that way before (Y) Good luck and I may have to buy one from you when you get the proto types dun
Can you get a 'mulching' blade for the mower? Chops stuff up real fine.No snow here from overnight... Hopefully I can find some time to get some of the leaves up... The grass is completely covered in some places and if I don't get them up before more fall, it will be overwhelming to the lawn mower....
Oh !! Ok, rev it up to 72 hundred maybe ?Doing it a bit different for high revs. Have to platy with it on the distributor machine to make sure it works out.
