805moparkid
Slant and AFX Guy
Indeed-I don't think he had access to those diagnostic tools...
i dont recall what plug and igntion system he was running.
The plugs were Champion RC9YC set at .035. The Edelbrock instructions called for a RC12YC but with those, I had a problem with dieseling/run on. The colder plugs stopped that.
I am using a Mopar Performance electronic distributor with the stiffest springs included in the tuning kit. It was set to 16 degrees initial with 14 degrees in the curve for a total of 30 degrees. The curve began at about 200 rpms off of a 900 rpm idle and was fully advanced by 2300 rpms (approx). I have used a Wells Ecu, an orange ECU and currently have a chrome ECU. Performance seemed similar with those factory based boxes. I also ran a Rev-n-nator but the engine knocked even worse. I retarded the timing as-per their suggestion, (2-6 degrees) but that left my initial timing so far back, it felt soggy out of the hole. The engine idled best at around 19-20 degrees of initial.
In my other long winded threads, I mentioned that I was using a wideband EUGO guage to tune after the cam was broken in. I was thinking that I may have been running too lean, possibly making it knock as a result. I up-jetted, down-jetted, changed power valves, set it to best idle vacuum....I was able to get the numbers to mid 14s at idle in Park, mid 14s at idle in gear and as low as 11.0 at WOT. I understand that 12.5 to 13.0 is the goal for the A/F readings at WOT. Even when I had it jetted to get those numbers, I still heard the knock.
By the way, wouldn't piston slap make more noise when the engine is cold? Mine sounds pretty quiet cold, warm or at operating temperature.
**** The EUGO guage setup uses an oxygen sensor that I plumbed into the RH header collector. I never tried moving it to the LH header to see if the left bank gave different readings.
12.5-13.0 A/F does sound fairly normal; did you ever run it any richer than that with differing effects on the detonation? I know we're hashing back through stuff that was already brought up, but I don't want to have to search back through another 6 page thread.
EDITED: misread other details...
And yes, EGT=Exhaust Gas Temperature...I don't think it's quite as simple as higher = leaner, lower = richer, but when you combine the readings with A/F or EGO info, you can better figure out what the engine needs.
To recap:
Bore size: 4.35 .
Stroke: 4.15.
Head chamber: 84 ccs
Head gasket bore: 4.410
Head gasket thickness: .039
Piston @ TDC: .017 below deck
Piston valve notch: 6 ccs
These numbers give me a 10.7 ratio according to the online CR calculators that I have tried.
The dynamic comes in at 8.09 according to another source.
Does quench make up for increased cylinder pressure and a jump in the dynamic ratio? The .027 Cometic puts me at .044 quench but puts my dynamic at almost 8.3. Since my cranking #s were already above 190, how could quench save me if the cranking comp goes to 195 or 200?
Was the block honed with a torque plate?
Looks like it may be sucking some oil thru the guides too.
Was the cam degreed and actually verified intake and exhaust lobes are what they are suppose to be?
With your numbers I also get 10.7:1 CR, but cranking should only be 177 lbs at most. Your dynamic is 9.08, not 8.0 with that cam in at 106.
If you had 1cc of carbon buildup in there it would be pretty bad looking. That's not changing your CR enough to matter.
I don't see 190 lbs on pump gas being a problem either. I can however see your ignition causing issues.
Personally I highly recommend putting it on a dyno with someone that has good tuning knowledge.
Have you ever tried driving the car without a hood on it so the engine can ingest some cooler air?
What is the average running temp of the engine normally?
Does it also ping when you lean on the engine when cold (within 5 minutes orso from startup)?
Perhaps it's time to consider that both hydraulic and solid cam timing events are recorded on the cam card at .050" lift, but during the engine operation with a solid cam, those events will be altered buy the valve lash, and the valve will be opening later and closing earlier.
Forget about running the compression on the edge. My 451 runs 9.5:1 compression and makes 694 HP with 906 heads.
Cylinder heads, cylinder heads, cylinder heads make horsepower on a pump gas street engine, not compression!
Curses, I broke my rule about not getting involved.
The engine does run better in the first few minutes before it is totally warmed up. The detonation worsens as it gets warmer. ...
Would you elaborate on that? What dynamics would affect a solid lifter movement at .050 if valve lash is anywhere from .010-.030"? How is solid lifter motion any different in a running vs. not running engine? Is the effect different at different rpms?
*The block was bored and honed. Torque plate? I'll have to check on that. I think the machinist said the machine is a Sunnen CK10?
*I incorrectly ran the engine for awhile with the intake manifold bolts too loose. Somehow I had my torque numbers wrong and I had them in at 15 lbs insteads of 35. I used to occasionally see oil in the valley pan under the middle of the manifold. I replaced the valley pan and didn't see any more oil come back. This was one of many areas I thought may be contributing to the knocking. It does look to be responsible for the carbon buildup, at least in my opinion.
*This was my first time degreeing the cam. I used the intake centerline method written in the instructions included with the degree kit. I never checked the exhaust lobes.
*I was pretty diligent about checking compression #s after every change I made. Maybe my guage is AFU. I will certainly retest the engine after it is up and running again. I can compare the new readings against what I recorded before, THEN recheck the engine with a higher quality guage.
*My Dynamic compression readings were calculated from this site:
https://www.uempistons.com/index.ph...=comp2&zenid=5886b5a1e26a6addce30f95974e64ff7
I listed the stroke as 4.15, the CR at 10.73 and the rod length at 6.76. For the intake closing, I took the 56.5 degrees from the cam card and added 15 for a 71.5 total. This gave me a Dynamic of 8.09. I'm open to look at other formulas though....
*In 2005 I had it tuned at a shop with a dyno. It was there where the man recurved the distributor, added bigger jets and advised me to get a more modern cam. I've followed the advice of some very qualified people and still have run into trouble.
Perhaps it's time to consider that both hydraulic and solid cam timing events are recorded on the cam card at .050" lift, but during the engine operation with a solid cam, those events will be altered buy the valve lash, and the valve will be opening later and closing earlier. With a hydraulic cam and solid cam having EXACTLY the same timing events at .050", the solid will build more cylinder pressure because of the valve lash, which is not included at .050" on the cam card. Oh-Oh. IT'S SIMPLE. Too much static compression and/or not a big enough cam! Get it right and you can lock the distributor and run 38 degrees advance and it won't detonate.
Considering this is your first time degreeing a cam and given the cranking compression of 190lbs, the one possible solutiuon is the cam is advanced roughly 10°. That also puts your Dynamic at 9.5.
Something to check.
He did degree it. But from what I remember, he was not 100% sure where it ended up.
Along those lines, you need to remember, most cam manufacturers grind 4* INTO the camshaft. So, even if you install and degree it "straight up" it is likely advanced 4* already. SO, if you installed it advanced, you can probably add 4* to wherever you installed it, which would raise cylinder pressure even more. I am sure you can call Lunasty and they will tell you whether that particular cam is ground with advance or not. I bet a dollar it is.
