1970Duster
- Joined
- May 30, 2010
- Messages
- 6,644
- Reaction score
- 215
3.91 or 4.10 reargear maybe?
The 1,2, & 3 ratios for the 200 are nearly the same as a low gear 904. Should work out great for you. But 2500 at 70? Seems kind of high to me but I could be wrong, been daily driving trucks for too long I guess.
what gear and height tire you running?
most likely they say it because they don't know what the hell they are talking about. same as the *** clowns that say a 904 won't hold up.
i asked my buddy that does all my transmissions for me about the 200 and he says they are very strong as long as they are built right. and by right i don't mean exotic and expensive..
i can't wait to see the install. this may just be the direction i end up going.
I am running 4.10 gears and need a good overdrive to drive this car anywhere. I want to drive this car wherever I want to go, and 4000 rpm at 70 mph ain't going to make that happen. I will probably run it on the track a few times for kicks and to see what times I can turn, but this is a street car all the way. I want to drive!
I don't know alot about trans gears but how does that 1-2-3 gear spread work out at the track with that 200 vs our 727?
Yes and yesIs there a Manual Valve Body option so no Kick down is required, how about a Transbrake?? Anyone?
Yes and yes
1970Duster;Gents I think we just found the tranny of choice for Mopar A-Bodies when it come to autos with overdrive and not cutting the tunnel (at least with the 68+ cars).
Mad DArt ,
As of now there isn't or at least I can't find anyone who has done it.. My one and only concern is if can hold up to power levels in excess of 700+ hp?
I hear you on that. Like to find someone who has taken it that far. Mine should easily do 800+hp and 800+ Tq to the tires. I wonder if there is even a converter available for this kind of power that would live?
I bet there is someone on yellowbullet.com that has put this trans to the test at higher HP/TQ levels.
Mad DArt ,
I have found a few people online who have done it. I just checked BBD, but that wasn't the place apparently. I would suggest calling Art Carr and ask for testimonials. I'm sure he has a lot. You keep bringing up the hp concern. It's not a concern. He builds them to all levels. Check his website if you want, or you can call and speak to him directly, which is better. The man knows his stuff. http://www.cpttransmission.com/
Ok 1st I want to start of by saying that I don't know anything about transmission and am only going by what I read and what others tell me. When I called CK and Jakes to inquire about the 200R4 which they both sell they both told me not to bother with it and do the 4l80 which was about the same price. Again I'm not sure why they would try and push me toward the 4l80 over the 200R4? I would rather run the 200 simply b/c of the size comparison between the two.
Just wondering mine is a 67 Dart and if there are any Trans Tunnel Modifications required to make this happen?? I'm not worried too much about the trans cross member cause building one of them would be easy enough.
Sorry Mad Dart, 67+ A-bodies is what I meant (I had a brain fart think the body style changed in 68).
Just talked to Art Carr.. I'm a believer to say the least.
