Go Mango
Never enough beer...
I charged my battery today.
That's all I've got.
Wish I was closer! I'd be glad to help. Please post some pictures when you get it on!
Looking forward to seeing it! Hope it works out for you!I got a helper and put it on... then ran around the car about 10 times trying to get the hinge bolts positioned just right. Finally got it close enough.
Unfortunately the paint is a lousy match - it's 2 shades darker, even though the same person did the fenders with the same gun, and the same brand of base with the exact same computer-generated mix was used. I got away with it having two different shops do the panels and the body though. It's always a crapshoot with metallic colors when you don't do the entire car at the same time... wondering if the gray fiberglass underneath is what affects the final shade.
Anyway I'd be embarrassed to post pics right now. Will be speaking with the painter but I suspect the only cure is to repaint the hood on the car so he's got something to match to.
Working hard to get my A500 swap ready for its first test drive.
Maybe tomorrow an actual test drive.
Hey desertrat, what kind of car is this? I see it has SS A pillar trim on it.Because I found out I could get a passenger side mirror I bought one and installed it today. View attachment 1715454774 No instructions but I didn't really need any. View attachment 1715454775 Tip-when installing imported parts, always chase the threads with a tap and die. Your install will go much smoother. View attachment 1715454776 The inside door panel must come off of course. The gasket between the mirror and body was a little small. I heated and glued it with weatherstrip adhesive before the final install. View attachment 1715454777 The mirror installed and the door panel and vapor barrier are reinstalled. Project done and moving on to my gauge cluster project. View attachment 1715454778
1967 Barracuda notch. All the SS on the car except the front & rear glass trimmers came on the car. I bought a 70K one owner car that hadn't been loved but hadn't been mistreated either. Just luck-----Hey desertrat, what kind of car is this? I see it has SS A pillar trim on it.
Pics or it didn't happenGot the starter fixed, put exhaust back on, filled the tranny and fired it up. It's still up on stands, but seems to go through the gears fine so guess I got the tranny back together correctly....lol. sometime in the next couple days I'll have it back on the ground and ready for a test drive, including overdrive.
