I'm posting spare parts for sale to fund my build(s).
Looking real nice!Got the car aligned... it drives perfectly straight (unless I hit the gas too hard, at which point it wants to go sideways!)
About +3.5 caster, -0.5 camber, 0.10 deg toe. Steering effort is non-trivial with the 16:1 manual box, but really not that noticeable except when stationary.
The required exhaust work is a bit more complicated than I'd thought, so that shop is going to do it Tuesday. So far the biggest problem is the engine oil leak (have to remove the front timing cover and straighten the lower rail and reseal it to the stud girdle. Already have a new Proform cover). But it's getting there. Now have 26 whole miles logged
Okay, makes sense now! Really like your car!No gas cap... I riveted a round plate over the stock opening. Probably should have done away with the recess entirely but I was not that confident in my body skills 10 gal fuel cell in the trunk.
Nice work, I like it. Details ---------------After installing the billet specialties pcv valve and breather along with the radiator cap i also decided to see if i could use the same cover for the oil fill and power steering. They came in yesterday and got the oil fill together pretty easily, had to cut the two tabs off of the oil cap and lightly tweak the lip of the oil cap to fit snug in the aluminum cover. The power steering cap was a pain as the outer diameter is a bit smaller than the inside diameter of the aluminum cap. I had to cut the two outer tabs off and had to grind down the bulge on the top of the cap and the edges of the lip so it would sit down in the aluminum cap, then i had to work the outer lip of the cap so it would fit tightly in the aluminum cap. I also swapped out the wing nut on my air cleaner for a scott drake billet one. Had to polish it with some mothers and a dremel as it came satin. I like the look much more than the plain factory caps, ties in nicely to the other aluminum.
Looks great man, and that's the same air/fuel gauge i'm installing right now.I did this today. Finished the install of my handbuilt gauge cluster. View attachment 1715467503 Details beginning to end are in my "cluster V2.0" thread. This is what I will see now when I get in the car. View attachment 1715467505
Couple things----I came through the floor near the edge and ran the sensor cable along the edge and up under the dash from there. The Innovate unit cable is calibrated to the computer so you cannot cut or change the cable without changing the computer unit so be sure to get the long cable.Looks great man, and that's the same air/fuel gauge i'm installing right now.
Just wondering where did you drill the hole to get the cable from the 02 sensor into the cabin?
Well, I bought the whole LC-2 kit so i have all the right cables and stuff, just trying to figure out the best way to get into the car without making huge hole.Couple things----I came through the floor near the edge and ran the sensor cable along the edge and up under the dash from there. The Innovate unit cable is calibrated to the computer so you cannot cut or change the cable without changing the computer unit so be sure to get the long cable.
