Nice plate!I did finish my center console and working on a front spoiler but it takes time and money that I have lots of time but no money. lolView attachment 1715680117 View attachment 1715680118
There is something vaguely familiar about that color??Nice sunny -13C day, so thought I'd get my car out for some vitamin B5.... of course I plowed a path first, not like the old days of taking this thing to the ski hills first thing in the AM before they'd plowed the roads!
View attachment 1715678739 View attachment 1715678740 View attachment 1715678741 View attachment 1715678742 View attachment 1715678743
Congratulations!I was able to get my car back on the ground and fired it up and moved it out of the garage so I can sweep the floor and clean up my mess. After getting my trans rebuilt and replacing, clutch,pressure plate and throwout bearing along with a rear main seal, HV oil pump, pan gasket, 90 degree oil filter adaptor gaskets and having my flywheel cut, oh and clutch linkage was also rebuilt. I went for a few mile ride and its like driving a different car. Trans used to be noisy through 1st and 3rd gear. I guess the bad output shaft bearing and almost non existent pilot bushing were causing the noise. Now its so quiet and all I hear is the exhaust note. Drove great for the few miles I did get to drive it. Back under the cover on the ground and bone dry on the floor. My huge project is a success.
So here are some pics. I know, the tach face needs to be straightened. But basically I used a hose clamp with 5/16" heat shrink slipped over prior to install. It's not 100% perfect, but for my application I'm happy with it. You can't really see the band around the steering column unless you really look for it.Righty Tighty can you show a Pic of the side of the column. Did you use long clamps?
I will disagree that the bolt you have pictured is the ONLY correct factory bolt.And a hardware store bolt to boot!
Stole the chip clips... now the kids 30 bags of potato chips are going to go stale... at least my door cards will be glued back down... this is 1 of 2 that need fixed a little. Not perfect but will work.
Edit... for some reason it may actually be worse than when it started... it seems to be bubbling real bad in the middle now... ill take pictures in a bit...
