Oh, and Kiwi Sid gave me a nick name while out at WOS, and it carried on to all he introduced me to. And Marie has a name for the car.
Please share.Oh, and Kiwi Sid gave me a nick name while out at WOS, and it carried on to all he introduced me to. And Marie has a name for the car.
a 383 with one plug wire off is 335. Just saying. So you could theoretically build a 425 and go for both records. (425 with a wire pulled is 371.8). So you could stroke the 383 (easier to get parts) and get there another way.Interesting. We can talk more about this. The only reason for this thread was to get that same engine under 372ci to lower the record from 246 to 224.
Well, the limit is 372.99 so technically it would work but barely3.75 crank and a stock bore is 425cu in
Edited to add;
That actually puts you over the 372 limit. It’s 372.391. But hopefully triggers thoughts on different ways to get there.
Well the class is B/CGALT = b engine size (373-439.99)/ classic gas altered. This is for rookie and shakedown runs. Then add boost.Please tell me about the class and what is the current record?
Kinda my thoughts. The big block has more head bolts for more boost, or how big of a deal is that honestly. I wouldn't think more than 18psi or so. This would be 5 miles of trying to get up to speed. Sustained high speed, high boost, high rpm for the measured mile from 4-5. Would be ideal. Honestly @TT5.9mag latest build would be perfect for power and displacement.
As mentioned in post #65What kind of hp are you looking for
That certainly eliminates "Exotic" Normally for a 372 cube I would look at a 340 stroker. But that's for best bang for Mopar dollar in a street build. Where low end torque is more desirable.The class is a classic category. No EFI, no controllers, etc
Definitely cant use the Hellcat blower. Can't run EFI.IF I was technically savvy.....
I'd build a 5.7 hemi with a 6.4 steel crank and a .010 overbore, for 360 inches . Then add the best heads I could find, along with an upgraded hellcat blower or twin turbos.
The guys offering the kit I found (takeout steel 6.4 crank and mahle pistons ) say it's good for 1100hp.
But I really like the takeout Nascar 358 idea too!
Please expand on this. Have you personally destroyed an engine at 751hp due to a block failure?Stock blocks are only good for 700 - 750 hp. When you get pressurized it just isn’t going to work
It wouldn't be cheating, just moves you to AA engine class. Then record is 246 for unblown or 255 for blownJust build a 600 plus cube big block and cheat. Screw it. You only live once.
Then, that incredibly expensive two foot tall carb manifold, (slight exaggeration) a big 4150 blowthru, and a couple turbos.Definitely cant use the Hellcat blower. Can't run EFI.
AA blown gas (or alcohol, fuel) is only 255mph? Seems like that could be a record worth chasing.It wouldn't be cheating, just moves you to AA engine class. Then record is 246 for unblown or 255 for blown
Now you’re talkin!Then, that incredibly expensive two foot tall carb manifold, (slight exaggeration) a big 4150 blowthru, and a couple turbos.
Only nine mph for a blower? Wow!It wouldn't be cheating, just moves you to AA engine class. Then record is 246 for unblown or 255 for blown
CBGALT is 255AA blown gas (or alcohol, fuel) is only 255mph? Seems like that could be a record worth chasing.
True but the R/S ratio is still too high.
I was giving examples of how I’d build it. And that’s the math that comes out.
Which BTW is pretty close to the deck heights in Pro Stock. IIRC they are in the 9.200 range with about a 3.6xx stroke.
