Unless the race car engine is being redone/redesigned, it’s all about having fun and trying things.Exactly my point. I THINK you got it. lol
Or perhaps he is just having fun?!?!
I think you both got it...Exactly my point. I THINK you got it. lol
Ok did not know that TF heads were only shaft
HR Magnum Short block
? how are you getting oil to the shafts- I recommend external from the rear of the block to the back of the heads and blocking off the cam bearing oiling by rotating the bearing- get more oil to the mains and rods this way
Is your block drilled for traditional LA block oiling- early magnums were but external is easy to do
I would also oil the rocker adjuster balls or cups with pushrod oiling
I liked cups on the adjusters and ball and ball pushrods- but others disagree and I need to find out why
you have some good recent comment from YR and NM
Back in business.
And I won't spend long on this.... but that goes back to application. I don't drag race... I rally (well, I drove rally cars...been a while now). Excess torque over a very wide RPM range is important because with 500 turns on a rally stage that are all different, you're gonna hit some gear-speed combo's where a narrow torque band engine is not going work. (BTDT! Young and dumb LOL) You need excess torque in a turn NOW to get the drive wheels spinning/slipping as part of steering the car on loose gravel (think of sprint cars only worse!). You can't wait even a fraction of a second 'til the engine rev's up a few hundred RPM; the brain-to-throttle-to-drive-wheel-spin/slip has to be an instantaneous connection to go fast.2500 is about as low as I'll go on a dyno pull. No reason to go lower. I'm not one to fret about what goes on at those RPM's. It just isn't worth it. It's like the head Porter who worries about flow under about .200 lift (depending on application). I look at those numbers, but don't fall on my grinder if I loose some flow there, for the right reasons.
I want to thank Mike for opening this tread back up. He took it upon himself to clean up the bickering without me reporting anything. Everyone is welcome to post here, please just keep it civil, and on subject. I have received PM's from a couple of members with apologies, for which I am grateful. Probably not needed, but grateful. Now with that is out of the way, let's get back at the subject at hand !!
So, I had looked at some stroker builds from Performance Injection Equipment some time ago. They are big into the Dodge Dakota racing/modification seene which use the Magnum series engines. They use the ported EQ cylinder head which have good flow. He told my that they used Bullet, and Comp to custom grind cam for them. It is interesting that they use slightly different cams for the LA carb based and Magnum injected based crate engines. Below are the specs, with their dyno results.
Carb cam: Hydraulic roller, duration @ .050: 224 / 230, lift: .565"/.565" 110 LSA
470 bhp@ 5,400 Rpm
520 btq @ 4,400 Rpm
Injected cam:Hydraulic roller, duration @ .050: 226 / 230, lift: .565"/.565" 110 LSA
Dyno Test Results
470 bhp@ 5,100 Rpm
512 btq @ 4,300 Rpm
Best flow and HP means very little to nothing if you don't have the necessary excess wheel torque over a wide range in that application. If your torque range reaches down another 500 RPM or more, it is truly golden in that kind of use.
Not criticizing anyone or any use... just trying to explain why the performance emphasis will vary. I see spirited street driving on curvy roads much more like rallying than drag racing. FWIW.....YMMV and all that good stuff, and may not be at all applicable for the OP's use.
You might be interested in Hipotek's cams. I have ran two.. one for NA 408 and now a supercharged 408. Both cams utilizing fuel injection. The NA cam was a Comp XFI 230/236 .576/.571 on a 108LSA. Tuner was able to tune my PCM to work with the 108LSA. I asked first before buying the cam and he said it would be no problem. Never noticed any brake issues since I have power brakes or any EFI issues.
Had plenty of torque down low and horsepower up in the high revs. Fairy rough idle. My shift points are set at 6200 RPM. This cam worked great! This is in a 03 reg cab dodge ram. Never have dynoed it but want to.
IMM engine
EQ heads/PAC beehive springs
EFI intake
long tube headers
58mm throttle body
PRW roller rockers
Full forged rotation assembly
True, but nice to see someone who has some tested options. The below cam is another option that he has. I copied to whole description for since it relates to your earlier post about lobe separation angles.
Duration @ .050 230 / 236
Lift .565" / .565"
This is a real good choice for more of a street / strip camshaft. It can still be toned down if it will be primarily used for a street driver. Just select the 114 degree lsa. The cam will work well with a looser converter and about 10.0:1 compression ratio.
Lobe Separation Angle Description
114 degree lsa provides smooth idle quality and provides a broad power curve. Engine vacuum will be increased. A wide lsa is a good choice for most forced induction applications. While a wide lsa does give a broad power curve it does reduce overlap which also reduces power. LSA is not as critical in smaller cam durations since the smaller cams do not have much overlap to start with.
112 degree lsa provides a slightly more noticeable idle over the 114 lsa. A slight power increase is possible with a tighter lsa due to the increase in overlap. 112 degree lsa also works well for a supercharged application
110 degree lsa provides a very noticeable idle. Power will be increased from the increase in overlap. Engine vacuum will be reduced from the overlap.
And unless you are NHRA class racing, who gives a rip about "maximum horsepower". 9 times out of 10 you sacrifice horsepower for torque at a certain RPM. You can build a big power engine and put it in a car with the wrong converter, rear gear, or tire size and it is almost worthless. THere again, on the dragstrip it's different. On the street it can be a waste.Oh absolutely! I will admit, if I had a dyno up my ***, I would test cams for my combo until I got the one with the most power......but I have to make my best guess. lol
The point I constantly try to make......yet get run over by a freight train(s) every single time.
There you go.....you are thinking right. On dirt and gravel and pavement, you can often 'modulate' the steering with torque changes, and you want some excess torque to be able to modulate around that point. In highway driving you are not under the same time pressure to want to avoid a gear shift if you fall out of the excess torque RPM range. It gets more critical if you are racing, especially on the hairy edge. I could go on ad nauseum upon the subject, but you obviously get it and can make the trade off.You know honestly that is closer to the driving I will do. Living in Oregon means going over either the Coast or Cascade Ranges with a lot of corners and hill sections While cam selection important to torque production, the one thing 408's are known for is a wide torque curve. The cam only dictates where it occurs at most. Also, I'm not sure having the torque coming on higher in the RPM range is a bad thing, as a lot of torque down low can lead just blowing off the tires. I could be wrong on that though.
But, but, but.... that is what the Thumpr cams do..... oh wait, that IS stupid LOL.Using LSA to change idle is crazy. In fact, I'll say it's stupid.
The 2nd part took me a while to grasp.... but I assume you mean that since the wider LSA moves the exhaust pull-through RPM's up, then the same duration moves the whole RPM band up...but you'll hit the physical RPM limits of the engine (oiling limits or valvetrain float) and have a narrow RPM range due to that. Is that right?You must reduce duration to open the LSA up, otherwise the engine will hold power past peak way too long, and you give up a TON in the middle and lower middle of the power curve doing that.
It wasn't very long. I can't remember right off hand but I think it was 6 or 7 months.How long did you run the XFI cam?
Last question, are you still running the melling lifters, and how are they holding up if they are still in the truck. I had contacted Richard awhile back, so he is on my radar as well as an option.
This has been in the back of my mind since this thread started: Should fuel mileage be thrown into the mix of trade-offs? OP? What is OK?
