dartfreak75
Restore it, Dont part it!
I think it's funny that in your very first post your suggestions where to replace the fuel filter and switch to efi! I recommended a fuel filter and that not the problem! I know a problem still persists because he is running 220 degrees at idle but according to the God of "garbage" A bodies (your words) 220 degrees is perfectly ok because it was setting in a garage.You didn't read: he hasn't test driven it since addressing the coil, so how would anyone know if the problem persists?
