Phreakish
You are so right, I have no idea what I was thinking. I wouldn't be caught dead in this stock garbage.
I accept your surrender.
Yes! The cooling system should keep the engine at a safe temperature regardless of the outside temperature or it something isn't working right.Even in a closed space like a garage? Me thinks not.
Garbage huh?You've obviously missed a huge portion of the thread.
The green wire is likely shorted to chassis ground caused by poor routing by the previous owner. Is it really that tough to understand?
The unhooked engine ground has zero to do with anything. It should be hooked up, but won't change a single thing about it, and has nothing to do with any of the other parts changes/additions.
Box stock, these cars are garbage - wouldn't want to drive a stock one around the block, let alone to get ice cream.
Bullshit that's why you have a fan! The fan moves air across it! It doesn't matter where the car is! In a garage or not the fan moves air through the radiator.Nope. An air cooled radiator can only achieve to much drop in temperature, the higher the air moving across it, the less heat it can remove from the coolant. An enclosed garage situation is unique and not a performance threshold of any kind.
B*******?....lol...Bullshit that's why you have a fan! The fan moves air across it! It doesn't matter where the car is! In a garage or not the fan moves air through the radiator.
For argument's sake what if it isn't cool air outside and it's one of those 117 degree Arizona days and it's 117 degree being sucked in to the radiator with the fan and the inside of the garage is actually 75° from the air conditioner in the house?....A fan that's recycling hot air from a garage isn't going to cool the radiator as well as a fan moving cool outside air that's cooler.
Pretty obvious..
Ok Mr know it all since 220 degrees is a perfectly ok running temperature then what's wrong with his car and why havent you fixed it yet?A fan that's recycling hot air from a garage isn't going to cool the radiator as well as a fan moving cool outside air that's cooler.
Pretty obvious..
For argument's sake what if it isn't cool air outside and it's one of those 117 degree Arizona days and it's 117 gruyere being sucked in to the radiator with the fan and the inside of the garage is actually 75° from the air conditioner in the house?....
For argument's sake: air flow when parked in a garage is reduced. I've observed it directly, and could calculate it if needed. I measured my own 3car garage air climbing over 120F after for 15-20 mins at the end of my commute. The air being pulled across the radiator, however, is poorly controlled by these chassis. When revving the engine, it would blow any small debris on my floor FORWARD. Now, I never had my thermometer right in front of the car (because I already knew idling in an enclosed space was dumb) but stepping across the front of the car it was apparent it was well beyond the ambient which was measuring 120 - Was it 130? who knows, but it was hotter for sure.
Also, anecdotally, the closer my grille whatever was directly ahead of my parked car (I had some stuff stored there which varied in space consumed), the faster the temp rose. This correlates with the air being blown forward too.
So it's not just a measure of ambient temp, it's available airflow (which is restricted) and the recycling of a local pocket of hot air that gets even hotter than ambient.
In open air, the recirculation is reduced substantially and the total amount of air flowing across the radiator is also increased.
I did. And the problems still there. Everytime someone tries to help you disagree with them and tell them they are wrong. Are you implying I'm not a useful member?Myself and other useful members have already helped him isolate an electrical issue with the coil which is likely to address his problem. Didn't read the rest of the thread?
That's because you have one of those big fancy yupi 3 car garages.. lol...Also, the garage might start at 75, but once that door opens it quickly reaches outside temps... Heck, my garage typically didn't even reach the house temp. On a 110-115 degree day (was 118F the day I left the city) my garage was typically 90-95.
Interesting. Airflow does things one might not think it will do, until you find out it does.
A SBM exhaust port (and some of the SBC exhaust ports too) will have air moving out of and into the port at the same time.
I was playing with some strings flowing a cast iron head years ago and I found it. I thought I was nuts. But it happens.
So it’s interesting but not surprising that in an enclosed space the air is moving forward.
I'd take one lolbig fancy yupi 3 car garages
*had LOLThat's because you have one of those big fancy yupi 3 car garages.. lol...
Was it 130° who knows?...For argument's sake: air flow when parked in a garage is reduced. I've observed it directly, and could calculate it if needed. I measured my own 3car garage air climbing over 120F after for 15-20 mins at the end of my commute. The air being pulled across the radiator, however, is poorly controlled by these chassis. When revving the engine, it would blow any small debris on my floor FORWARD. Now, I never had my thermometer right in front of the car (because I already knew idling in an enclosed space was dumb) but stepping across the front of the car it was apparent it was well beyond the ambient which was measuring 120 - Was it 130? who knows, but it was hotter for sure.
Was one of the garages separate and had a little door for your golf cart???...*had LOL
Now I have a redneck barn.
This sounds like a guesstimation and a theory of yours?... Most liked to work on scientific fact...
