12:05 Garage- ’70 Duster build
Denny, I'm not "bitching". You made some comments about bump steer on these cars with factory suspension that are in fact not accurate. I know that for a fact because I've literally done the EXACT things you said would cause bump steer. And they don't. And frankly that shouldn't be that surprising because a well engineered suspension system should not be so susceptible to bump steer that changing the static alignment will result in a dramatic change.
Now, if you want to call that "bitching" and compare me to your wife, well, that says more about you than me.
I kinda don't think that was all he was doing. But maybe I'm wrong.
It's fine. I'll stop screwing up Tim's thread, I'm truly interested in his modifications and suspension geometry numbers because no one else that's done a coil over conversion has ever posted them.
It's hot or miss whenever I search either one.. Searching within a specific group seems to work OK on fb... ie search trx filter housing while in g3 Hemi swap.
Looks like you quoted a different post than you intended.
Either way, fb still isn’t a place you can just read a thread even if you can find individual posts.
Not sure how I did that lol
Last year at Cruising the Coast autocross, I had a Moparty friend ride with me and I rode with him in his Demon. His first comment was how much better I would do with a better seat. I always thought my seats were pretty good. After riding in his car that has much more supportive seats, I realized I needed to do something. Not looking to replace the fronts I have permanently, I figured I'd just get a driver seat for race days and just make it a simple drop in. Turns out racing seats aren't necessarily cheap, so I let it the idea go. I've been slowly selling unneeded parts on Marketplace and ran across a guy selling a racing seat in my area for a decent price. So here it is. Maybe I won't need to brace my knees on the console and door anymore.
Nice!
Seems I read somewhere one time that in a Foxbody they have to add bracing to the floor as well. Seems that while a good seat can hold you well, in the Rustang the seat itself moves around a bunch and they lose some of the benefits of the good seat.
Not sure if our cars could have a similar problem, but might be something to think about as you are working this in.
Can't wait to see how you come up with a quick disconnect so you can swap between the 2 seats. :D
I was teasing a buddy last weekend about this. He has a BB Dart and a '67 Belvedere and only one set of seats. I told him he needed to figure out how to make the seats swappable between the 2 so he doesn't have to spend money on a second interior.
Nice!
I plan on making it just a drop in replacement. 4 nuts off the bottom and pull it out. I was thinking of making a square with some flatbar to put on the bottom side. Need to look closer to see if its even worth the effort. The outside holes are right next to that "bump" in the floor where bench seats mount. It's a pretty sturdy section of floor.
when i replaced the bench seat in my valiant with mercedes leather buckets i stiffened/reinforced the floor with 4" squares of 3mm plate welded to the underside of the floor.
neil.
For those following along that have any interest in pro-touring cars that actually get driven on the autocross or race track, I started a podcast talking to guys that own and drive these types of cars. They aren't all mopars. The first two interviews are Fords, the second two are Mopars. That's not really on purpose, its just way it happened. I do have a couple chevy guys in the que. Anyway, you can find the show on any of your favorite podcast platforms. Just search for "Talbot's Turn Fast Podcast" or if you're not into that type of thing, you can listen on your computer here --> Talbots Turn Fast Podcast | talbotsturnfastpodcast
I'll admit my audio isn't great on the first interview. My computer auto switched to the computer mic instead of my external mic. The audio on the second interview is great. Please consider listening, I'd appreciate it. Also share with your friends that may be interested.
I finally decided to get my brake upgrade done. I was previously using the stock style proportioning valve that came on the Dodge Magnum my front discs came from. It worked fine with the rear disc brakes. The car would stop really well, but honestly couldn't lock the brakes up. I decided to ditch the stock style proportioning valve and go with an adjustable valve. That meant I had to make some new brake lines. Of course, the hardest two fittings to access had leaks after letting them sit overnight. It took a couple hours and some bruised forearms to get them to stop leaking.
I had a hard time deciding what color to paint the calipers, but finally decided on silver with red lettering. I think they came out fairly decent. These calipers were black with the viper logo on them. I bead blasted them down to clean aluminum in preparation for the Cerakote paint. Amazon had some cheap Brembo vinyl I used for masking purposes.
Instead of using my hand pump to bleed the brakes, I removed the hand pump and connected it to a vacuum pump (the type used to vacuum AC systems). It worked great. I highly recommend doing this if you have lots of air to get out of your lines, and of course if you have those tools available.
The pedal has a very good feel to it. I'm ready for a test drive, but it's been raining pretty much every day for the last month here and there's no end in sight.
View attachment 1715763991 View attachment 1715763994 View attachment 1715763995 View attachment 1715763997 View attachment 1715763998 View attachment 1715763999 View attachment 1715764000
You don't happen to know a rough OD of this setup do you? I doubt it would fit in my 17's but if it did, it would save me a lot of work. On a quick measurement it looks like the ID of my wheels is right about 15".
I can measure it for you. It’s not on the car anymore, so it’s easy to measure. Actually thinking of selling the spindles with hubs and calipers. If I remember correctly, the rotors are just under 14”.
I run hubs I purchased from Bergman Auto Craft. They may be the same hubs that DrDiff used to offer. I run GEN III Viper Brembo calipers with the SRT 14.1" rotor. The Enkei PR01 (18x9 +35) wheels would not clear the hubs. I found a small local machine shop that was kind enough to machine down the hubs to clear the wheels. There is no way a 17" wheel will clear the calipers on this setup. You MAY try a 13.3" rotor with a 17". I run a 255/40-18 Michelin that is 26" tall. Hope these pictures help.
Weren't those Challenger Scat Pack rear rotors? Those are 13.78" (350mm).
I think some of the SP and Hellcat guys are able to run 17" wheels over those rotors, so they might fit?
I should add that my front brake setup is 13" Cobra rotors and C5 vette calipers and just barely fit my 17" wheels. No way a bigger rotor would fit a 17" wheel with these calipers. So the calipers you run have a huge impact.
Yeah, I am wondering if the 350mm will be too much. kinda thinking it will. I have the same first Gen Viper calipers which are surprisingly compact compared to some of the others I've seen including the Vette ones.
Yeah those are really nice but no way I'm fitting a 14.1" rotor inside 17s.
If you take a picture directly from the side and give me a measurement of something in the picture (hub diameter for example), I could sketch up one of those tests like Baer does. Then @bjkadron could print it to scale and check his wheels with it.
No promises it would be perfect but it would give good idea if it would work.
I know this isn’t exactly the same combination, but I checked the clearance on the DoctorDiff Stage 4 kit (13" rotors, Viper calipers) with my 17" spare from an '07/08 Infiniti G35. It does clear, so, the Stage 4 kit can be used with some 17" wheels. This particular wheel also cleared my stage 3 kit as well. I would definitely not take this to mean the stage 3 and 4 kits will clear ALL 17" wheels, but it certainly does work with some. But again, that’s a 13” rotor not a 14”.
FYI, back when Joe was working on that brake setup, I did a layout to see if a similar setup would fit in my 17" rims. Minimum wheel barrel measurement I got was 15.5".
Note that it was just a preliminary layout, the caliper was just a sketch off an image. So it could be off. And this is worst case, could be that at the narrowest point in the barrel of the wheel the caliper is actually smaller than the above images makes it look.
Your pictures don't work! And I really want to see them.
:lol:
Yup, these work now. Those are the radial mount calipers so the shape is a little different then the first gen.
I have the stock 2004 mustang bullet wheels and with the wheel weights I'm thinking 13" is going to be the maximum. Just figured I'd check because the MB rotors from the 13" viper kit need to be re-drilled. the Challenger ones RacerJoe uses don't.
Really I think 18s are the way to go. For tires, tie rod and balljoint clearance. But I have the 17's and have a lot of other things to do before I get to the 18s.
That might not be true. Looks like the MB bolt pattern is 5x112 and if the hole is big enough, a 1/2" stud on a 5x4.5/114.3 pattern might just slide in. The rotor I looked up showed a 0.6"/15.3mm diameter stud hole and a quick AutoCAD layout says it should just fit.
This is correct. I have the MB CL500 rotors as part of the Stage 4 kit, they fit without any redrilling. I spoke to Cass about that because I like to know what the options are for replacements.
The 13” MB rotor is nicer in that respect than the 13” C4 rotor used with the stage 3 kit, because that rotor has to be redrilled to work (Cass orders blank C4 rotors and has them drilled). The CL500 rotor for the stage 4 kit can be bought off the shelf from anywhere and works out of the box.
Either way the 18’s have much better clearance
I like it.
Looks like you could up to 14" rotors, too. :poke:
:lol:
This is news for me. Is Cass Dr Diff? I could have sworn I asked him about them and he said the ones he supplies are re-drilled. if they fit off the shelf then I think that is probably the best option because they have the smaller Diameter and the thicker width.
Yes, Cass is Dr. Diff. Not saying he doesn't redrill them, I wouldn't be surprised that people complain if they have to carefully slip them on. And tolerances might be that 4 out of 5 fit and one doesn't and by redrilling them he doesn't run the risk of someone posting bad comments on the internet. Could be he just hits them with a 5/8" bit to make sure they are opened up enough, too. Not sure. And Blu said he talked to Cass and that they aren't redrilled, so there is that too.
I'm just saying if the specs match reality, they should be very close to slipping right on. I would buy one locally and try it. If it doesn't work, returns are easy.
Hmm...something else I just thought of. If the knurl on the stud sticks out past the hub face, it could cause the rotor not to seat. I was only looking at the stud itself.
