JBrian
I didn't have any problems with brake components or suspension because I bought everything from Bergman Auto Craft. Just saying...
This is news for me. Is Cass Dr Diff? I could have sworn I asked him about them and he said the ones he supplies are re-drilled. if they fit off the shelf then I think that is probably the best option because they have the smaller Diameter and the thicker width.
Yes, Cass is Dr. Diff. Not saying he doesn't redrill them, I wouldn't be surprised that people complain if they have to carefully slip them on. And tolerances might be that 4 out of 5 fit and one doesn't and by redrilling them he doesn't run the risk of someone posting bad comments on the internet. Could be he just hits them with a 5/8" bit to make sure they are opened up enough, too. Not sure. And Blu said he talked to Cass and that they aren't redrilled, so there is that too.
I'm just saying if the specs match reality, they should be very close to slipping right on. I would buy one locally and try it. If it doesn't work, returns are easy.
Hmm...something else I just thought of. If the knurl on the stud sticks out past the hub face, it could cause the rotor not to seat. I was only looking at the stud itself.
Yup, Makes sense. I Think they are the best fit of everything else I'm looking for so they are probably the best choice. Worst case re-drilling isn't that hard.Yes, Cass is Dr. Diff. Not saying he doesn't redrill them, I wouldn't be surprised that people complain if they have to carefully slip them on. And tolerances might be that 4 out of 5 fit and one doesn't and by redrilling them he doesn't run the risk of someone posting bad comments on the internet. Could be he just hits them with a 5/8" bit to make sure they are opened up enough, too. Not sure. And Blu said he talked to Cass and that they aren't redrilled, so there is that too.
Well that is fantastic news! Glad I asked!So I don’t have a picture of the rotor by itself on the hub but the Stage 4 rotors are not redrilled at all. They fit tight, so you do have to make sure they seat all the down on the hub, but they don’t need any opening up of the lug holes. With this size picture I’m not sure it will be obvious but in the original and of course in person it’s obvious that nothing is done to the CL500 rotors. The stage 3 rotors on the right are clearly redrilled from 5x4.75”
Not sure who this is directed at, but I haven’t had any issues with brake or suspension components either, everything from Cass at DoctorDiff has fit and worked exactly as advertised.
It’s not like BAC sells parts that are all from the same manufacturer or vehicle.
I think he is just saying he didn't have to think about all this as BAC did all the legwork for him. Minus machining the hubs to fit his wheels anyways.
I didn’t have to think about where the rotors came from either. I just like to know because if DoctorDiff stops selling a certain kit I want to be able to support pad and rotor changes down the road.
I'm no expert, but I think both banks are running a tad lean!I know I've been a little quiet lately. Lots of other things going on besides car stuff. Some may remember I killed an O2 sensor shortly after getting the hemi running. I replaced it and it worked fine for a very short time and that sensor failed. I didn't quite understand why since I had thousands of miles of trouble free service out of the same gauge and sensor. The only thing that changed was the bung. I replaced it when I redid the exhaust for the hemi. It turns out the bung I purchased was too short which was putting the sensor too deep into the pipe and I was cooking them. It was a 1/2" long bung. Some research showed me that Innovate Motorsports supplies a 1" bung with their kit. A quick call to them to confirmed my thinking. I had been wanting to upgrade to the dual sensor gauge so this was the right time to do it. Sticking with the same brand also allowed me to reuse the bezel that I painted.
The sensor doesn't even protrude out of the 1" bung. Both sensors are now installed. I still need to go drive it to see how even they are. Installing this did require some additional wiring. The second sensor has its own controller and it sends the data to the gauge via CAN bus. That controller needed power and ground. The second sensor also has 2 analog outputs. I don't have any spare analog inputs on my ECU, otherwise I'd split the fuel tables and have 02 correction for each bank individually. Maybe one day I'll get an I/O extender.
I am interested to see if there are any major differences bank to bank.
Lol! so lean it isn't even running!I'm no expert, but I think both banks are running a tad lean!
I'm getting anxious! For once I don't feel rushed trying to get the car ready. But still lots of things to check.
that's when you relax thinking there's lots of time and then you still end up rushing at the last minute neil.I'm getting anxious! For once I don't feel rushed trying to get the car ready. But still lots of things to check.
Well, I do have some maintenance to do on my truck before I tow for 1200 miles. As for the car, the biggest thing to do is make an alignment adjustment/check. After that, its just pretty much nut and bolt check, and change the oil in the engine since I'm sure its broken in by now. We have a local autocross the weekend before Moparty. I usually tend to stay away from doing those so close to a planned out of town trip, but I haven't auto crossed since I fixed the power steering, so I think I'll go. That leaves me with 4 days to fix something if it breaks.that's when you relax thinking there's lots of time and then you still end up rushing at the last minute neil.
So are you going to be trying out this setup?@HemiDenny , @DionR , @75slant6 , check this out! This is another Ride Tech product that come with their Mustang kits. It uses a S550 Mustang hub, so the bolt pattern is 5x4.5. They also have a caliper brackets that will allow the use of the S550 brake components. I'm not seeing these parts listed individually on their webpage, only included in kits. I kinda wish I would have found this earlier. This open options to use a factory Brembo caliper and have parts store availability for replacement parts.
I've really been thinking about trying the Ride Tech spindles for the GM A,B,&X body that accept the corvette hub and brake assembly. Since I already own the hubs and brakes, I would only need the spindles and steering arms. If I were to go with the Ford version, I'd have to get brakes, hubs, rotors, etc.So are you going to be trying out this setup?
