Well any members get lucky?
wasn't I who bought it...it was gettin up there!
Your snout is 10.75" long?
You can get a shorter one and that will bring your lower pulley closer to the engine. The further away the pulley is, the more stress will be put on your crankshaft.
IDK, the snout with shaft is around $400 and the elect fans will be pricey too.
Ok, I got 5" from the front of the harmonic balancer to the front of the lower blower pulley. 6rib and due to different harmonic balancers, I will give you some more dimensions. I am running a 2 groove March aluminum crank pulley.
My snout is 9.75"
From the center of the front driverside intake manifold bolt to the front of the upper blower pulley, I have 8 1/8"
IDK, you might be able to open up the crank pulleys inside diameter and reduce the blower pulleys outside diameter to let them fit inside of eachother?
I'm Just wondering if you kept your Electric water pump and ran dual electric fans if you wouldn't have the clearance issues....I talked to Mezerie the other day after we P.M.'d and I feel confident I can run my electric water pump on the street and also keep my heater by running a heater hose line direct to the radiator low pressure side and the other to the intake manifold port. Heres a pic of what I'm researching to make work now....add a F.A.S.T EFI and keep it under the hood, It's a Mod-Man intake modified for a whipple system. I'll be watching to see that you come up with. Good Luck...
That's a neat setup right there! I just got rid of my CSR electric water pump. I really don't know how they will hold up on the street! I hope you get yours going soon!
Nice!! How is the distributor clearance?
Badass James. You have to take me on a ride in that thing when it is done. What about e fans from behind the grill?
MSD 6BTM Box with one step colder spark plugs gapped on the tight side.
HEY DUDE!! Pretty cool idea, those little blowers work great.
