I like the Fratzog. The blue to match the interior is a great idea.
I’m not very goid at editing a photo, so something like this:
Those DMT seals are excellent. Agree with you Don!Next thing to add to the firewall is the driver’s side fresh air vent. I bought one with a working door hinge as so many are broken - the one originally on the car was missing the door all together. The vent needed to be cleaned, old hard foam Seal removed, door stripped of runny paint, painted and maybe even a quick coat of black on the vent. After removing the old foam seal and hand sanding the vent as well as the door, it got a couple light coats of satin black paint, new foam on the inside of the door and new foam seal on top. The seals were another super item from DMT - no they’re not sponsoring me - they’ve got great products that actually work and fit as they should. Vent Is now ready to install tomorrow!
Looks great! Where to place it?How about something like this? Or change the red to blue to match the interior color?
That would look awesome! Are you making the sticky or magnetic?I’m thinking on both upper panels that replaced the rear quarter windows. They would likely be decals.
Kinda 3D thing!I haven’t made any firm decision but would lean towards a permanent decal. What would be great if I could fabricate a dimensional logo that would show some depth!
I hope to finish the cleanup and get a coat of paint on the housing tomorrow or the next day
It's a littlle time consuming, remember from the convertible and the wagon! But it feels great to small things like that gone through! As you know DMT has the isolation but there is a company that sell all the gaskets and o-rings for the compressor too! I'll see if I can find his address for you Don.Mt sandblaster guy called and wanted to know if I had any more sandblasting to do in the near future. I decided to bring him in and get him to sandblast at least one of the AC housing, covers and drip tray. That way I’ll know they’ll be clean with no stinking residue inside the evaporator chamber. If it wasn’t gonna cost an arm and a leg, I just might get both done. So i hurried up and got the other one scrapped out.
The drip pan that needed the drain replaced went well, i cut off the old drain, ground it smooth and opened the hole up to accept the 3/8 copper plumbing fitting (a coupler). Got it soldered in place so it looks like it’s never been replaced. Should look nice and round coming through the firewall (unless i ding it up installing the AC housing lol!)
Ah, sweet.Thanks but not necessary! Classic Air has already rebuilt my compressor and restored all the hoses. A fellow member and friend FWDLK Frank was going ro a school in Alabama and made a trip to delivery my stuff and his 65 Valiant and 59 Fury AC parts. Saved a bunch on shipping both ways. My compressor and hoses aee tucked away ready to be installed
Top notch!So much progress today - my sandblaster guy came by as did my bodyman friend. So, first things first - I knew that the chances of the door rubber causing issues with the door alignment was a distinct possibility so i installed it first. I bought it from Restoration Specialties as they were the only ones who had the light blue metallic windlace/door rubber seal. Also I HAD TO see what the repro upper rocker panel trim was going to look like - it is gorgeous with the mounting holes matching the OEM holes in the panel (both from the 4 door and 2 door addition. Many thanks to @65dartcharger who highly recommended this restoration grade part from Layson’s as that’s what Ulf used on his DartCharger as well as their carpet holddowns - which I have on hand.
So we got the passenger door hung and immediately found out that the door rubber was indeed causing issues. I kind of figured that by using a entirely different door (the 2 door sedan door) instead of the original 4 door was gonna cause issues. The final solution was to “adjust” the pinchweld to allow sufficient room between the door and rubber yet still seal the door. Then the next issue on the door was the window frame didn’t align worth a hoot with the upper B pillar. Again, my bodyman guru knew what to do so the door has decent gaps and aligns completely with the B pillar. Next was the passenger fender which went on well other than the hood hydraulic lift interfered a little with the fender. It took a small adjustment on the fender and relocating the bottom mounting point on the lift for no interference.
We got the driver’s door hung and ran into the same door to door rubber interference as the bottom of the door was right up against the original pinchweld. Some “adjustments” on the pinchweld again solved the problem. I’ll leave the doors closed for a week or so and see if the rubber relaxes anymore. I knew this build was not going to be a piece of cake with all the modifications I’ve done and it’s come to pass. Pictures of the passenger side will have to suffice for now.
My ever-so-slow sandblaster guy did not fail me! Before he could even start, he had to empty the hopper as he thought he had water in there. Nope it was condensation in the hose. Them it was refill the hopper and of course sifting the sand again so it wouldn’t clog the nozzle. I swear he milks the time. Well, rant over as I did discuss it with him. So he got all the pieces of the AC part of the system blasted and painted them black for me!
The main Housing - passenger compartment side and firewall side:
View attachment 1715627866 View attachment 1715627867 View attachment 1715627868 View attachment 1715627869
Evaporator compartment cover:
And evaporator drip pan - bottom and evaporator side.View attachment 1715627870View attachment 1715627871
I’ll be installing the insulation snd seals in a couple of days
Top notch!
Denatured alcohol I would guess.
Awesome Don! That will stand out!As @65dartcharger has said, it’s the little things that count as well as the big things. I was getting ready to install the tailgate “D O D G E” letters and thought they don’t look all that great even after polishing them with fine steel wool. It was the insides of the letters - really faded black. I bought a pint of gloss black and a fine tip artist’s brush and went to work on them. They look so much better - the little things do make a difference.
Before:
After:View attachment 1715642960
