uh oh, sellers remorse maybe in another 10 years i might have this worthy of swapping for the Hemi carYour gonna sell it to me,right ? I'll still trade ya my Hemi car for it....
me too. well, except the 76' capri that had already had an engine fire when i bought it. half the wiring harness was a brittle chard mess, but it ran. but the Mopars, yesI feel that way with every car I've sold.
looking real good!Looking good !
what's not to love about factory welds...
K member is welded up and back in the car. added a B-body Shumacher torque strap that fit almost perfectly, and a slightly used Firm Feel sector shaft support i got at a good price from HemiDenny. Firm Feels directions are a little vague . basically it's "install like this 9 year old Mopar Action article says but, invert the nut".
i do canyon carving just going around the block i don't want the steering wheel to feel neglected. planning on some track days and maybe get back to auto-xing.So since you're addin reinforcements like that, I guess you're gonna do some canyon carving?
doh! that's a pain. still better to fix it now than it leak out on the road somewhere and cause even bigger problems.so what happens when you get it driving? you move on to the next project and start tearing it apart again as hot as it's been i figured i would take a break from working on the car, but it's supposed to drop 20' from what it was a couple days ago, so screw it, i'm wrenching
rear end is next up while i'm waiting on a fan shroud. the car came with an 8 3/4" housing and axles, just another reason it was such a good deal. thanks again Darter6 going with 3.73's and an Eaton sure-trac from Dr Diff.
so when inspecting things after the old rear was out, i notice a not too old drip line from the fuel sender lock ring, and that it's not quite seated.
well that's easy to fix... one tap with the hammer and the freakin seal tore gas starts pouring out all over the place. lucky i had a drain pan handy.
and of course i had just filled it...guess i was due, i hadn't done anything truly stupid in quite a while.
anyway it's mostly drained. the house didn't blow up, but i did shut off the water heater for a bit.
