340sFastback
@72bluNblu Yes Silver Sport bellhousing. Its real bulky on those two upper edges. Maybe a tad of material, 1/8" or so, could be removed without affecting strength?
@72bluNblu The bolt on the top of the trans is pressed hard up against the floor. The edge of the bellhousing is pressed hard up on the floor. The floor is pressed up onto the heat duct. The floor up to pinch weld has been removed just the firewall metal is left. I am going to pull that plastic off to get a better look next time I get out there:
The bottom edge of the trans is contacting the trans cross member. But I could slightly clearance the cross member to get around that issue:
Here is a side shot to show location of shifter relative to trans cross member. Offset arm is 2.75". Trans looks further back to me then other installs I have seen:
The TTI headers just barely miss the steering linkage so if the engine is lowered the headers will lay right on the steering linkage. Right now trans and bellhousing are pressed hard on the floor and floor is pushed hard on the floor heat duct. The engine would need to drop at least 1/4" or more which would have the headers laying right on the steering linkage. If I went with custom headers yes lowering the engine would solve the problem.is there any wiggle room to drop the motor a bit? that and maybe slot the trans crossmember holes where it bolts to the car could get you where you need to be. it won't need much, if you can get a little on the motor and a little on the trans.......
neil.
Hmm. Have you checked the driveline angle at all? Could be sitting up a smidge too high at the tail, and anything would help.
Looking at the transmission mount bolts I really don’t thing the transmission is any further back than mine, not more than a 1/2” for sure. I don’t have that same side shot but you can see how far back the shifter sits, and from the bottom you can see if the transmission was another 1/2” back that next bolt on the shift cover would be behind the crossmember…
never thought about that but that might be a viable option. Not sure how that would affect torsion bar and steering column alignment though?Could you space the K Member down like they did on the hemi cars?
I see your point mine might be farther back then yours but probably less then 1/2" so its not dramatically farther back like I originally thought.
Haven't checked the driveline angle. But rear of trans would have to drop probably way over an inch in order to get trans and bellhousing to clear floor heat duct. Right now I have to jack the trans up to the point where the entire car lifts up on its suspension in order to get the cross member bolts in and even then can only get 3 of the 4 bolts to go through. I can not get a gap in between the trans and trans mount even with trans jacking up to the point entire car is lifted up. The trans will not go up due to steel floor heat duct preventing trans and bell housing from going any higher. I have the entire top of the trans tunnel cut out now which allows me to clearly see trans to tunnel clearances and only clearance issue is up at firewall with the floor heat duct.
A lot of ppl put spacers between k frame and frame no issues with torsion bars and steering shaft. But it does change the camber. Usually 1/2" or less spacers don't cause too much of a camber issue. But k frame spacers definitely change drive line angle although ppl who added spacers never complained about vibrations maybe they stayed within angle tolerances.You’d need to lower the torsion bar anchors in the crossmember to do that yeah? Or raise the LCA pivot tube? You can’t put much angle on the bars before they bind. I’m not familiar with all the tricks they used on the hemi cars
I put the cherry picker on the engine lift plate, loosened both motor mounts, and moved engine forward as much as I could. I would have to move engine forward 1/4 inch or more to alleviate the clearance issue at floor/heat duct and giant dents in headers would be required. I could widen k frame motor mount slots to allow engine to go more forward but then headers would need big dents to clear steering linkage.Is there any room to shift the engine forward? Like even a tiny bit? Basically not modifying mounts or anything, just loosening the engine mounts and seeing if it will shift forward on the mounts.
agreed, you'd only need 1/4-1/2" so the torsion bars will be fine. to check just loosen the bolts and slip in some c shaped plywood spacers. once you know it works make up some steel spacers, remove one bolt at a time and fit them. if the trans needs lowering slot the crossmember bolts til you're happy then weld washers to it to cover the slots.Could you space the K Member down like they did on the hemi cars?
Been reading on k frame spacers most ppl say up to 1/2" with an alignment and its fine. Apparently its commonly done by many people with no adverse side affects.agreed, you'd only need 1/4-1/2" so the torsion bars will be fine. to check just loosen the bolts and slip in some c shaped plywood spacers. once you know it works make up some steel spacers, remove one bolt at a time and fit them. if the trans needs lowering slot the crossmember bolts til you're happy then weld washers to it to cover the slots.
it's only metal, lol.
neil.
I am going to check engine/trans and pinion angles next. Then maybe temp space that k frame like you suggest and recheck angles. But yeah just 3/8" or so lower I think I can get the required clearance.
My LCA bushings are rubber so prob a lot more flex. Ppl who dropped their k frame never mentioned bushing types. They do say camber is affected because distance between upper and lower control arms is greater. And headers exhaust will hang lower etc. So something to mull over and consider. Driveline angle will help me in that decision too.Worth a shot anyway.
I wonder if rubber LCA bushings and unboxed LCA’s allow for more misalignment there.
I wouldn’t think you’d have quite that much tolerance with delrin LCA bushings and LCA’s that have been tightened up at the lever arm and boxed. But I haven’t tried it, just thinking out loud
Yeah I was saying above I need to pull the hvac box anyway to get floor duct out of the way of tunnel work. And hvac box needs a rebuild cause I was planning to put AC in before next summer. And AC been unhooked since 1981 and main hvac never been out of the 54 year old car so its all crudded up for sure. Once hvac box out I can cut floor heat duct off and fab a new one that sits 3/4" to 1" higher for the raised tunnel. You'all been telling me make tunnel roomy and now that trans is up in there yeah I want the tunnel to be nice and roomy not tight.I would mod the floor and the HVAC box over messing with the K-frame. I think you'll get it no problem that way.
Won't be doing anything other then driveline angles for next week or so. I wanna pause and think everything through. Plus body is worn down needs rest at this point.
But that hvac box might be coming out one way or another next because I don't feel like having that floor duct in the way of that tunnel work and no way to tunnel work under floor duct other then weld from under car or panel bond. I think that hvac box needs to be pulled regardless of approach since it needs a rebuild for AC going back in near term and I need it out of the way.
Was planning on a kit from Original Air with Sanden compressor and modern condenser all new under hood and recondition original hvac box with DMT kit. My heater portion of the box I know that is not broken and through the life of the car I been only one that did heater core replacements etc. So I don't think anything is broken under there and all the vacuum still works etc.I think taking the HVAC box out is probably a good idea. I agree with @goldduster318 too, I'd much rather modify the lower ducts than anything else.
it'd be quicker to slip in some 1/2" plywood spacers just to check viability than remove the heater unit and mod' the tunnel some more. if you gain the clearance you need just swap in steel spacers and you're done. also you mention the headers will hang lower, that's not the case. the motor is still bolted to the k member the same, all you've done is raise the body by 1/2" up from the k. so in relation to any of the suspension that's close to the ground the headers remain the same.
neil.
Spacers will move kframe and engine down so torsion bars will need to be adjusted to compensate resulting in headers and exhaust hanging lower relative to the body of the car and lower to the ground. Yes its only 1/2 inch but headers exhaust hanging lower falls in the negative affect category as does changing the front end geometry.You’re putting the headers lower to the ground with respect to the body of the car.
Whether you consider that raising the body or lowering the headers is up to you. I think it’s safe to say most of us set the ride height of the car based on the height of the body and not just the K frame, so, I’d say the headers would be getting closer to the ground because I’d be keeping the body at the same height.
Its a viable solution and a good suggestion. It comes down to preference of approach and judgement call. I have to pull hvac box anyway before next summer to freshen up for AC install and it has to be pulled to gain access to floor sheet metal under heat duct. So hvac box has to be pulled now its not an optional thing anymore regardless of approach.everybody seems to be forgetting we're talking 1/2", not 3" or more. really, it's 1/2". can we please have some perspective, it won't make the car a dangerous death trap will it. once the alignment is reset the difference will probably be un noticeable. remember...... 1/2".
neil.
