As long as its not one of those carpentry pancake compressors it will run a low pressure gun, they only work on like 15 psi, not 90 psi like the old school suction cup guns.I've only got a very small air compressor..
Yep that's basically what I have LOL I think it's a 6 gallon 150 psi...As long as its not one of those carpentry pancake compressors it will run a low pressure gun, they only work on like 15 psi, not 90 psi like the old school suction cup guns.
If you get to that point use a foam brush. I used semi-gloss black tremclad (rustoleum) to seal the bottom of my dart and put it on heavy and it self levels and basically leaves no brush strokes. Wouldn't reccommend it for visible body panels maybe, but for floor and underside and where it is less visible it worked great.^^^ worst case scenario I'll just break out the paintbrush..
I kind of like this product being water soluble as even if I have some moisture in my air compressor it wouldn't hurt it...If you get to that point use a foam brush. I used semi-gloss black tremclad (rustoleum) to seal the bottom of my dart and put it on heavy and it self levels and basically leaves no brush strokes. Wouldn't reccommend it for visible body panels maybe, but for floor and underside and where it is less visible it worked great.
Looking good by the way. Making good progress. Looking forward to seeing it all come together.
I'd hit that area that bubbled up with solvent and some course sand paper.
It looks like there is a chemical reaction with a foreign substance
After the sandblasting I gave that tunnel a good scrub with Dawn soap and water yesterday and then it let it dry overnight. Pretty much tried to handle it with rubber gloves as well. Again it didn't bubble from underneath it just bubbled the second coat. I think and I don't know but really I'm thinking it was the application of the second coat just too quick and too thick as the instructions say between 2 and 4 hours not 5 minutes...I agree with fishmens67, probably just a little spot of grease, dirt or sometimes even a fingerprint will leave enough foreign material to wrinkle the paint. I usually wipe my parts with prep-sol to make sure they are ultra clean before applying paint.
Anyway, just a suggestion. I’m enjoying your build thread, thanks for posting.
Check out this 4 minute video...I use rust bullet metal blast to clean and etch bare metal before top coating.
It kind of reminds me of SEM Rust shield which I've used. It's not water based like the stuff your using though.I bought a gallon of this newfangled rust encapsulator / primer coat stuff and it can be mixed with 20% water for spraying in a gun.. I think I'm going to spend the $16 and buy one of those Harbor Freight guns with my cheap little Harbor Freight compressor and see if I can't do my floorboards..
That's a pretty good video link on Amazon.. it's pretty good reviews as well. I've got a pint of por15 coming but I think I'm going to go with this.. it says the gallon will cover a thousand square feet which should be enough to do my next three projects LOL but of course a pint probably just fall a tick short.. (I know my luck LOL...)
Yes totally my rattle can days ended today! I did take the gun apart and cleaned it with some mineral spirits all the inner parts and everything. And it even an instruction says to sand that rod a little bit and you can see the crud on it and how smooth it feels after you just sand it for 1 minute. But that said I put a little mineral spirits and kind of sprayed it out to clean it and then use that to kind of adjust it. then I put a little bit of water in it to clean that out and spread it out because the product that I use is water soluble... I also watch some videos on just buying a can of industrial strength enamel rustoleum from home Depot and I think don't quote me but using acetone four to one...I’ve always used rattle can paint, my whole life till this day. Maybe I should just get past the fear of mixing and spraying and air pressure etc etc and just go buy a cheap gun like y’all say and just learn how to do it.
Keep up the work jpar.
Okay learned a lot today...
First the $16 Harbor Freight spray gun is completely awesome! .. completely changed my outlook on painting.. likely won't buy any more rattle cans again.. I'll probably just use up what I have and buy industrial enamel...
My little 6 gallon Harbor Freight compressor did fine for this little trial but I do think it would be nice to have something bigger..
So what I learned about spraying this xionlabs 2 in 1 stuff.. I was seeing how it would work on non-rusted metal, my dog house that was partially sandblasted and still had some Factory paint. The first coat went on really nice and I probably should have stopped right there.. I didn't let it 100% dry by any means but went on with a thick second coat and I believe that's what ended up peeling on it.. lesson learned..
View attachment 1715757065 View attachment 1715757071 View attachment 1715757072 View attachment 1715757073 View attachment 1715757075
It's like The Good the bad and the ugly LOL but when I took my heavy wire brush on that ugly part that flanked it just knocked off a few of the flakes and was still Rock solid like concrete..
I think tomorrow I'll just scrub and wash my floorboards and let them dry overnight and then Monday try and mix up some the stuff and spray the floorboard inside and out.. WITH ONE COAT!! LOL...
The first layer went down perfect. The first layer is still there and is still perfect. It's the second layer that's peeling in small areas.. even when I take a heavy wire brush on it the first layer is like cement... The product can be painted over wet metal and I used 20% distilled water to thin it.. I find it hard to believe a tick of moisture in the line is going to hurt it... I strongly believe it's just like the instructions said if I'm going to put a second layer it should be between the two to four hour time mark not 3 to 5 minutes later and twice as thick... They even talk about the second coat if you're going to use a second coat to be thinner..It almost looks like a moisture problem. It shouldn't have peeled simply because you jumped the gun on the 2nd coat I don't believe. Are you using some kinda moisture filter? Even those little cheapy red plastic inline ones are better than nuthin.
Again in the future with this specific product I will probably just put one coat and use like it says any kind of pain for a second coat... 48 hours later of course as per instructions...
