- Joined
- Dec 31, 2005
- Messages
- 7,517
- Reaction score
- 4,404
If you want to believe those numbers are set in stone then pay your money and get your heads done so they get exactly the number you want.So being an unhelpful dick.
All I'm doing is simply pointing out the flawed assumptions and holes in claims people make.
Shhh.......You'll get sacrificed on the alter of the hot rod engine builder gods for pointing that out. The emperor has no clothes.True
True
Why would velocity matter?How about you point us to what you have built, how many championships you have and then tell us how to do it?
I’ve tried to stay out of these velocity threads because as someone is pointing out, velocity is over rated.
While Morgan did say velocity velocity velocity, he also said he is a VELOCITY MANAGER.
I know I’ve done heads done by these screaming velocity types and every one of them I corrected went faster. Every single time.
And the tune up window was wider.
Velocity is over rated.
It's to help to get you into the ballpark, it don't need to be 100% accurate, and it's probably far more accurate than any actual advice you would probably give, when people are coming up with a combination.No one said he was fucked you did. All I'm pointing out is those numbers do not account for all the variables in a running engine. If you want to use them go right ahead.
Software trumps Physics.Don’t believe that bullshit. His software works.
Tell me why velocity mattersNo, you said his **** doesn’t work because it can’t.
So I suggest you call him and tell him how stupid he is and let him see what a fart smeller you are.
That guy has forgotten more than you’ll ever think you know.
To trash him and his work is chicken **** and despicable.
Go tell him rather than slam him on the web like a little *****.
Your posts are a perfect example of why guys like Larry don’t post here. Or damn near anywhere.
You tell me. You’re the genius here.Tell me why velocity matters
I'm well aware of it, but it's not absolute. nothing isHis software works.
You pointed out that Darin Morgan said he is a velocity manager did you not. Why is velocity important.You tell me. You’re the genius here.
But he has a chart and DV preaches it so it must be true.I'm well aware of it, but it's not absolute. nothing is
Shorter rods move away from TDC sooner than longer rods that dwell longer a TDC, so with longer rods there's little piston movement so overlap and velocity are generally starting off the intake charge, shorter rods the also has some piston movement to help early on the intake charge supposedly lessoning the need of higher velocity.Anyone?
True but nobody is arguing it is.I'm well aware of it, but it's not absolute. nothing is
Did you make the assumption that the fuel droplets are all the same size and uniform in weight as they leave the carb and magically turn corners like gasses do?I’m stupid. I’m waiting for you to explain it to me.
Then I’ll know.
Hurry up
Let me guess you think a formula can tell you what size droplet the fuel is when it has to travel past the exhaust charge as it travels up the intake port with your magical formula.
Do gasses separate from the air stream and coalesce into pools of liquid in the chamber.......
This is basic physics.......different objects of weight and size travel differently in a pipe. How much of it is a gas and how much of it is still a liquid.......
But I have a formula.
What happens when you increase the vacuum in the plenum?I make NO assumptions. So why not explain to me how YOU determine fuel droplet size and then how you determine it’s even correct.
I’m still waiting…
Apparently it's not his job to know, just to harass people when making reasonable choices for their builds and to show them how some car made x hp & e.t. with "smaller".I make NO assumptions. So why not explain to me how YOU determine fuel droplet size and then how you determine it’s even correct.
I’m still waiting…
Pay your money and target what ever velocity you want.Hysteric - you are arguing with yourself. Nobody here is making the presumption you think they (we) are. Its fine to think about what is probably happening in a real pulsing engine compared with a dry or a wet bench. Nobody is arguing with that either.
The strawman statements are wear on everyone. Let people speak for themselves, and make their own points. If you don't understand a point, then ask if xxxyyz is what they meant. Let them answer.
