post your 9second and quicker combo's here!
this is my 79 AMC Spirit 331 N/A sbc. 6.09 1/8 mi. 1.29 60 ft. 112 mph
408 LA, Indy 360-1 heads with Fierra valves, n/a tall fill block, Hughes main bearing girdle, Ross coated pistons @ about 13.0 to 1, Moroso vacuum pump, Eagle crank and rods, kevko rear sump aluminum oil pan, T&D rockers, TTI 1.7/8" headers, XS 16 volt agm battery, MSD 6al ignition, 2 speed Reid glide, S&W fab 9", 4 link back half and 14 point cage, Ron Davis radiator with Meziere pump, RMS front end, race ready at 2510 lbs.
Absolutely awesome car you have there sir! What a cool combo.
stock block 360/408 4 inch stroke 4.030 bore 11/5 comp sb indy crap heads 256/262 cam 600 lift 4 barrel holley 200 shot twin 3 inch pipes 4 mufflers 2 spd glide 4200 stall 4.11 9 inch home made caltracs radial tyres tow bar full street trim 3550 lbs 9.57@142
here is a mate s 6 cld 265 ci turbo factory 6 cld block and crank glide 9 inch 2750 lbs more specs are in vid
Ian, this thread is about how you did it to help others do it and you have not given any details.
So what was the point of the post then?
"Barbie"
Engine:
440 Mopar Raised Block
446 cubic inches
Wiseco pistons
Ohio Crank rods
Stock steel crank
Indy 440-1 Easy heads and intake
Heads/intake ported by Killians
Isky 660 roller cam QA shocks
Isky red zone roller lifters
Harland Sharp roller rockers Chassis:
1050 APD race alcohol dominator Full round tube
Transmission:
JW Power glide
PTC spragless 5500 converter
Fab 9" 40 spline axels
Strange aluminum case
4:57 gears
MSD 7 AL ignition and distributor Funny Car cage
Aero Space Vacuum pump 4 Link
Dan's dragster oil pan 2550 Lbs. without driver
Performance: Best 9:36 @ 142 MPH @ SGM
Holly Crap.... I know that Bad Azz Ride !!!!!!!!!!! :thumbsup:
"Barbie"
Engine:
446 cubic inches
Wiseco pistons
Ohio Crank rods
Stock steel crank
Transmission:
JW Power glide
4:57 gears
Hey, what the heck, we have a 13,12,10, second combo thread(s) going on and I figured, why the heck not have a section for the guys reallly puttin it down hard. While 10's are no joke, getting that extra second or even 2 seconds E.T. knocked off is tuffer than......Ahhh..... well, you guys know.
OK, let us know!
Engine CID and it's goodies
trans & stall
rear and gear
suspension and tires
Your rides weight
How many donuts ya gave up to help
Enquiring minds wanna know and day dream about it. :read2:
Finally got out to the 1/4 mile track at Rock Falls WI. The weather was perfect with 70 degrees and sunny. This was the first time at this track with these heads. So now I get to move from the 10 sec to the 9 sec forum. The car is a white 1976 feather duster gutted out to be a racer. Here are the details
iron block 440 stroked to 508 with a kit from Muscle Motors
Flattop pistons from ICON
RPM H-beam rods
block filled with hard block to just above the freeze plugs
ARP main and head studs
cheap roller timing chain
Hughes Engineering main girdle (that drips oil, be warned)
stock oil pump
homemade 7 qt deep center sump oil pan with extended pickup and slosh baffle.
mopar windage tray
Edelbrock Victor intake
Edelbrock Super Victor standard port heads with pocket porting only
440 source .650 offset roller rocker arms (they tear up rocker shafts, be warned)
Crower standard pushrods
Crower MM305 solid flat tappet cam (from Andy Finkbeiner's book)
electric water pump
electric fan
no alternator
MSD 6AL
440 Source aluminum water pump housing
440 Source cheap aluminum distributor
4X16 air filter
MSD conventional round blaster coil
battery in trunk
Unaltered out of the box Holley dominator 1050 CFM 3 circuit carb
TTI 2 inch chassis headers with 14 inch collector extensions
Hughes Performance 9 in torque converter 4500 rpm stall
30 year old Cheetah reverse pattern full manual valve body (no transbrake)
Lightened sun shell and upgraded servos from PATC Transmissions
Aluminum 3.5 in driveshaft from Dennys Driveshafts with 1350 U joints
Strange Dana S60 rearend with 4.10 gears and strange 35 spline axles
Wilwood disc brakes solid rotor front and scalloped and drilled rotor in back
Mancini aluminum manual master cylinder
fiberglass bumpers and hood
the rest is all original steel and 10 pt plain steel roll cage
Cal Tracs with their split mono leaf springs, set at no preload.
cheap fiberglass bucket seat from Summit
30X9 Phoenix slicks
15X8 wheels
Replaced torsion bars with Viking coil over shocks from QA1
Stock K member
I launch just off idle at about 1900 RPM and seem to be going through the traps at 6,700. I shift at 6,400 but it seems to be falling off in power by then.
The car weighs 2,800 or 3,000 with driver and gas. This calculates to about 650 HP.
No nitrous or turbo or electronics.
I'm pretty happy with this, but you always start thinking about what could be done next. Selling the torqueflite and get a powerglide, would be the next logical step I suppose. Any suggestions? Oh, and the timeslip was my best the yesterday, but I redlighted cause I couldn't see the last amber in the setting sun and tried to leave on the second last light and guessed wrong. The other driver saw my redlight in his mirror and let off. The competition is stiff and if you don't get a good light, you can forget it.
The engine was built almost entirely based upon Andy's book How to Build Max Performance Mopar Big Blocks. This book should be required reading for any big block driver. The car and engine and transmission was homebuilt in a two stall garage with only ordinary machine work and the roll cage done by outside help.
Certainly not the only way to get into the 9s but this seems to work.
Nice! Crowed makes some really nice cams. Some of there rollers are crazy.
Andy F is here so I hope he reads this.
And yes, gooooood book!
1973 Dodge Dartsport. 2" x 3" Alston chassis. Weighs 2640 with me and fuel, race ready. 2450 without driver. 8.50 chassis cert. Ladder bar, Coil over shocks. Front shocks are Santhuff custom built. tubular upper and lower control arms, rack and pinion steering, Fiberglass hood and rear bumper, lexan windshield, rear window, and door windows.
540 cu. in. Built by Andy Jensen. Bill Mitchell aluminum block. 4.5" bore x 4.25 stroke , Callis 8 bolt crank, JE pistons, Oliver rods with chevy size crank ends. Brodix B1-BS/ heads. Comp cams roller- custom grind. Gross valve lift .658 intake, .661 exhaust, duration at .020 tappet lift 308 intake and 316 exhaust. Installed at 104 intake center line. Lobe separation 108.0. Compression a little over 14.2 to 1. Dominator 1050 Ultra on a M1 intake. (heads and intake are holding me back) Msd 7AL2 ignition and billet distributor. Engine was a fresh build this spring.
Copes Racing 727 transmission. Rollerized , with steel billet drum, Griner trans brake. I am foot braking the car the last 5 years. PTC 8" converter, flashes to 5700 rpm. I launch the car at 2000 rpm. Shift at 6100 rpm, and go thru the traps at 6900 rpm.
Ford 9" rear. With 4.30 gears. 35 splin Moser axles. All wildwood brakes. Hoosier 32" x 13.5W x 15" slicks.
Mark Williams Aluminum driveshaft. Billet front yoke.
Bg 400 fuel pump and regulator.
Best et: 9.173 at 145.53 mph.
Best 60': 1.238 60 foot.
410ci na 1.31 60, 9.03@147mph, 5.71@120mph, foot brake
A8 block, 4.15borex3.80stroke, W9 heads, PAC springs, titanium valves, Jessel Rockers Kinsler stack injection, dry sump, Carrillo Rods, JE 15.1pistons, Bryant crank, 50mm Cam 268@50 780lift, Step headers 1 7/8 to 2 into 3.5
3000lbs Au Charger, 727 8in 5500stall, 9in 40spline 4.30gears, leafs, Caltracs, double adjustable Qa1shocks on the front Afco out back, anti roll bar, 29x12 tyres, 8 point cage
Working on suspension and should go a little quicker when hooked
On the throttle stop?
71 dodge demon 540 indy uluminum low deck13.1 roller cam, Chapman's mopar stage 6 heads, Eddy intake, 4500 1050 gas carb. Motor makes 842 and 740 tq.
Bob's profab front suspension, call tracs, leaf springs, afco double adjustable shocks.m/t 29.5 10.5 slick, 3.73 gears. 727 A&A trans. Glass hood,bumpers, street legal. With 3 inch exhaust best run 9.06 1.31 60ft. @ 148.44. I 1/8 it was 5.77 alltitude 880. No power adders. Weight with me 3100lbs. Just trying hard to get a 8.99!
Please tell me you have a photo. Sounds amazing!
