Newbomb Turk
Wow I thought I missed you. I guess I was wrong about that too.
Did the truth hurt your feelings?
Here's some pictures you might find thought provoking. These are side by side intake port molds of an OOTB SBM Edelbrock RPM head and a Trick Flow 190. Also a pic of the TF intake bowl. I was a little blown away by the bowl design downstream of the guide on the TF. Looks like this design is one of 3 things, or maybe a combination.
-Fuel shear ridge
-Swirl inducing (or swirl canceling because of the direction)
-A fix (or band aid) for the flow stall that happens after the venturi convergence point of 0.500 lift
I really don't know the answer, but I hope to find out. I'd love to get the facts, but opinions would be interesting as well.
What did you use to take those port molds? Thank you.Here's some pictures you might find thought provoking. These are side by side intake port molds of an OOTB SBM Edelbrock RPM head and a Trick Flow 190. Also a pic of the TF intake bowl. I was a little blown away by the bowl design downstream of the guide on the TF. Looks like this design is one of 3 things, or maybe a combination.
-Fuel shear ridge
Been enjoying the fireworks. I do have a few more thoughts, but I’ll have to post them later. Working on my daughter’s house today.Sorry we messed up your post. Please carry on.
https://www.amazon.com/gp/product/B09M9XKPFW/?tag=fabo03-20What did you use to take those port molds? Thank you.
This is the silicone that I used. It’s enough for 7-8 molds at least. It is a pain to get out of the port. Takes about 10-15 minutes to work it out. I use a Jorgensen style clamp to push on the intake side while pulling by hand on the valve side. I think a lower density silicone would be easier to get out, but this one works.
I really like the molds. Helps me visualize the whole port better.
I have only used WD-40. Think mrc would be better?Did you ever try spraying the port with a mold release compound
What’s the head those are sitting on? That’s some good looking chambers.It’s been so long since I bought any mold compound that I forgot the name of the company I went with. They offered a pump spray compound so I bought some. It worked ok but then again I was playing with bigger B1 ports.
I must have missed the truth. All I asked was proof that 52-55 degree seats were the way to go and you didn’t post up any. And now I know way. I’ve provided 9.30 time slips with common 45 degree seats. You haven’t. It seems to provide high flow number on W8, W9 stuff but from what I’ve seen kills the low lift numbers. Most of us are budget racers and need low lift flow numbers to make the horsepower our budget needs.
Seriously? He asks a question and you want to take it sideways?Why? Your mind is made up. Go learn for yourself. Or not.
Your time slips don’t mean **** to me. By all means, keep doing what you do.
YepHey is 'you know who' back on again?
Still pot stirring! Keep on stirring! Round and round it goes, just like a toilet bowl!Sadly, you are just repeating what you don’t know. I don’t need to prove anything. Just keep on doing what you do. What makes no sense is why all the butthurt?
Go prove they don’t make more power and that low lift means anything.
How about answering the question?
Or is it you can’t?
Yep
Why don’t you STFU and ether help or leave?
How about trying something new, like, not being a dick.
LOL. Ok prick. I am helping. You and John won’t listen. So why bother?
If you are going to live and die by flow bench numbers you will NEVER figure it out.
Go learn that.
Once again what are you going by. You quit racing. Lol
Take it to PM , you'll have a much better conversation. I assure you.I guess so. When you hide under a hidden identity you may get called out on something.
You know as well as I do. John's stuff runs very good.Why? Your mind is made up. Go learn for yourself. Or not.
LMAO, from one prick to another….LOL. Ok prick.
No, your being cryptic and insultive.I am helping.
Incorrect on my behalf, it’s not why I won’t listen, it’s why won’t you listen.You and John won’t listen. So why bother?
Learned that long ago and you should have known that but then again, when your head swells up so much from being convinced, your ears close and your eyes become shut.If you are going to live and die by flow bench numbers you will NEVER figure it out.
Go learn that.
Asserting an assumption as fact. You do this over and over which shift the goal posts, point of the issue, an obvious blurring of the lines and facts of what was said while twisting the conversation to suite your objective.So? Because you bracket race that is impressive?
Pay attention!
Don’t high school girls argue like this?
If you were actually serious about helping, you would have pontificated on the issue already, but yet, instead, you cryptically reply, and insult. Twisting words, and blurring the objective of the subject. You are so, not helping. Only a blind man or a complete idiot can’t see this.
I put John in as one of the top porters in the country with the results he gets with any port he works. heads and intakes.That has zero to do with porting or anything else.
There is always room for improvement, it just depends on how far you want to go.Are you saying his stuff is so good there isn’t room for improvement?
Good adviceLet’s see. I said stick a piece of string in the port. You can learn a ton from that.
So you assume I don’t understand. But this you know I do and you said it for one purpose only…And then it became about seat angle. Why should I explain something to you that you are incapable of understanding?
Let me say it this way so maybe you can grasp it.
know this stuff, next! And moving along moving along….Are you getting ANY of this? I can’t make it any more simple than that.
Again, if you live and die by the flow bench you will never figure it out.
And so the suggestion is there is only one way to do it and everyone else is wrong.Just like the 100% idiotic notion that a 30 degree seat, with whatever limit you put on lift (let’s say you decide you want to run .480 lift convention says that should be a 30 degree seat) is a proven power maker. It’s not. Not with any lift constraints.
That’s why I said (if you were paying attention) that lift does NOT matter when choosing a valve job.
So you assume again.Think on this. Or not. Some of you can’t learn. You’d rather argue that your way of doing things is all that.
