B3422w5
American casting ?
no, Chinese
American casting ?
See if you can get some specs and pricing… maybe when you do we can start a Bloomer head thread….
The guy is not exactly the king of marketing… where is his contact information to be had?just call him and ask.
I know a drag week car that had just put them on( pump gas 416) went 132 mph in summer air with them and the combo still needs tweaking..
Convertor off, etc, etc
Their instructions state that the head bolts or studs/nuts kits they list as items being “required” A need for the flanged reduced bolt head (9/16” hex) or the smaller 12-point nuts for tool clearance is obvious, but I never checked to see if the bolt lengths were the same as the factory bolts. Have you checked the lengths of all the studs your using? I assume they are the correct lengths and it’s just the reduced bolt head/nut size that’s different.Ok one thing I forgot to mention the other day my favorite set of intake gaskets that I usually have 5-10 sets laying around which is Edelbrock 7276 fits the intake face perfectly. First thing I found out today after checking intake and exhaust calibration was don’t expect to use the regular 1/2 inch National Fine nuts on the outside bolt holes. These will require the smaller 12 point head nuts. View attachment 1715800258
Right now they are the ( KING )Been pleased with my TF 240 and 190s. One of the best bang for the buck heads out there.
Is the interface to the flow bench through a serial port, USB, or something else? Just wondering if the old crap I have around here could be put to use.
Very coolOk this is going across the shortside floor. The straight, common wall tapers in almost the whole way down to the shortside losing area. As you can see my meter is pegged 3/4 of the way across then starts backing off rapidly. The shortside is blocking that area and that is the real good air heading into the center of the head chamber. At .550 lift it only gets worse. These heads are very nice but don’t even think about going with a bigger valve or making big horsepower till that’s addressed. Is there metal left to open it up. Hopefully time will tell. I’m going to flow the exhaust View attachment 1715801547 tomorrow and try to call TrickFlow. I tried today but it was close to closing time and no one picked up. They did exactly what they wanted to do with this head. They made a great street, street strip head. Mission accomplished.
How far into the port is your velocity probe for those numbers? Fun stuffOk I’m going to lose a few guys but maybe others can maybe put things in better words. All numbers listed are FPS (foot per second) my readings limit out at 401 which is to damn fast. The picture is marked top, bottom, pinch, and common wall. As you can see the dinky port entrance maxes out on the whole port wall at the pinch with great numbers everywhere else. View attachment 1715801542
