Stop in for a cup of coffee
well anyone know where I can get a couple of the rollers for the quarter windows for a 74 dart? mine are shot
Those are the coolest looking coupes on the road. It looks like a nice car and those 3 litre v6's run forever. They originally came out in Mopar mini vans.
If they are in fact the same engine,the run forever. But picture shows a different engine than the 3.0 in my caravan.
It just spit a belt,no damage except to my wallet.
that 3.0 was a low power engine. Other then that not bad.
Chrysler Mitsubishi 3.0L V6 Engine
The Engine's Weaknesses
Over the years, the MMC 3.0L V6 has proven itself to be a real workhorse capable of racking up lots of miles. Some of these engines have gone 200,000 to 300,000 miles in aging minivans! But the years and miles also have revealed the engine's major weaknesses. The main ones are oil leaks, oil consumption and valve guide/seal problems. The bottom end has proven to be rock solid but the valve guides and seals (especially in the earlier motors) have been troublesome.
In the back of each of the OHC heads is a black round rubber cam plug. If this plug pops out, the engine will quickly dump its oil supply and self-destruct. The cam plugs tend to loosen up during extremely cold weather so it is important to make sure they are leak-free and tight. If you replace these plugs, make sure you use the later "improved" versions, which are wider than the original narrow plugs.
The Positive Crankcase Ventilation (PCV) system on the 3.0L V6 sucks blowby vapors from the crankcase through the baffles that are built into the valve covers. There is also a drain hole in the covers so excess oil can drain back into the engine. If the drain hole becomes plugged, oil can be drawn into the PCV system causing a huge increase in the engine's appetite for oil. Likewise, if the baffles are clogged with sludge, pressure can build up in the crankcase forcing oil to leak past other gaskets and seals in the engine. There is no way to clean the baffles because they are located between the inner and outer liners in the valve covers. So if the valve covers are dirty and caked with varnish and sludge, they should be replaced with new ones.
To prevent sludge from returning, change the oil and filter regularly. Short-trip, stop-and-go driving especially during cold weather accelerates the buildup of moisture in the crankcase making 3,000-mile or three-month oil changes a must.
The 3.0L V6 uses pressed-in valve guides, which may work loose as the engine ages. The problem occurs mostly with the exhaust guides and allows oil to leak past the guide seal into the exhaust port. Chrysler says oil consumption is excessive if the engine uses more than one quart in 1,000 miles on vehicles with less than 50,000 miles on the odometer, or more than one quart in 750 miles on higher mileage engines. On engines built since 11/15/91 (build code BDL7.067), snap rings have been
installed on the exhaust guides at the factory to prevent them from slipping, and on engines built since 10/2/92 (build code BDL7.416) the intake and exhaust valve stem seals were revised to improve oil control. The build code label can be found on the intake plenum.
Chrysler Technical Service Bulletin 09-18-92 describes the oil consumption problem and offers the following repair advice. If a 3.0L V6 is burning too much oil and/or blue smoke is visible in the exhaust, check compression and verify the correct operation of the PCV system to rule out these as possible causes of the oil usage. If both are okay, remove the intake plenum and manifold, then the valve cover, rocker shaft and cam bearing cap assembly on the front head. Remove one of the cam journal caps from the assembly and reinstall it on the head to hold the cam in place so the cam does not come out of the journals when the engine is rotated later.
Examine the valve guides. If any can be moved with finger pressure or appear to be higher or lower than the others, the head will have to be removed so the guides can be replaced. Chrysler says the guides must be replaced if the distance from the top of the exhaust guide to the valve guide boss on the head is 0.335" (8.5 mm) or less.
If the guides are not loose and have not slipped, a special tool (MD998790) can be used to cut grooves in the exhaust guides so clips can be installed to prevent them from coming loose. Use a magnet and a shop towel to remove the cuttings. Then install new positive valve seals on the guides, reassemble the valvetrain and valve cover and repeat the same procedure on the rear head.
Same here. Mostly drizzle. Not bad to walk in. Radar shows some heavier stuff might hit later.
So far - no leaks - fingers crossed.
Got a little work done on the car yesterday. Took the grinder to the alternator pulley. Cut the neck down so the removal tool fit over it. Fought removal the whole way. Compared to an original the ID of the pulley is smaller than it ought to have been. Wieghed in at over 1# 7oz vs a factory single groove pulley at 7.5 oz. Folks are always looking how to make big changes, but one of the secrets of removing weight or building power is a lot of small steps. Take it where you can. Damn thing didn't quite line up right either as some of the guys noted at Dave's house.
Also fired up the engine and checked the charging circuit. 14.2 - 14.4 volts at the regulator input and 14.8 to 15.0 at the bulkhead connector. That's what I thought might be going on. 1/2 volt drop with only a couple amps through it. Sunday will pull it apart and replace terminals or recrimp as needed.
15.0 volts is the max that it should put out...
The 3.0L V6 uses pressed-in valve guides, which may work loose as the engine ages. The problem occurs mostly with the exhaust guides and allows oil to leak past the guide seal into the exhaust port. Chrysler says oil consumption is excessive if the engine uses more than one quart in 1,000 miles on vehicles with less than 50,000 miles on the odometer, or more than one quart in 750 miles on higher mileage engines. On engines built since 11/15/91 (build code BDL7.067), snap rings have been View attachment 1715271367
One cery common issue not covered is the lifters (cam followers) rattle.
They bleed down and sometimes dont pump back up. I have had 3 of these vans and they all did it.
My last one, a 99 still does it.
They gum up.
Sea foam and motor medic quieten them until the next oil change. Been doing it for years. Just annoying.
My Wifes 06 Chry 300 has the 3.5 high output engine in it. Usually they put the 2.7 in them. But this was a fleet car, that I bought at a dealer only auction in Nov 06. Only had 13K on it. So I think they put the better engine in them. I really wanted the Hemi car, but there were none that looked this good at that auction. Besides the fact that my wife would drive it 90 % of the time. But WOW... I could not believe the Pep the 3.5 has when I drove it home. She dont need no Hemi.....Now has 130k on it. Runs like a Kenyan...LOL....
The 3.5 is a modern designed 4 cam 4 valve engine. The 3.0 no so much. two cam 2 valve non performance engine...
I have been in conversation with a FBBO member north of me that has a original 65 Coronet 440 2 dr. ht. he would sell. 3rd owner, California car, 60,000 miles, Poly, PS-PB. Looks pretty nice. I would have to go look at it.
62- 65 B Body's Rule.......
I had a 97 intrepid,3.3. Great engine. Pushrod engine. I think it would run 100 mph all day long,even having 300,000 km’s on it.
So my vote is on the 3.3 and 3.8 for good engines in the older fwd’s.
Its only doing that because the regulator isn't seeing the 15 V.
Something in the wires or connections from the bulkhead to the regulator that causing over 0.5 Volt drop.
So the regulator thinks its letting through just enough current for the alternator to be 14.2 - 14.4 V
Brought another car home today, decided to get the Chrysler, real clean car and drives super smooth and nice....I think the boy will like it...he’ll be home soon
Finally took you off the wall today, Rick.
Nothing personal. It was just time.
Replaced it with Tim's work of art, nothing shabby.
Evening fellers.
Just got done with my commute. Saw a wreck on the interstate. It was on the other side and into the median and didn't look too bad so I kept going.
Then i stopped to help a guy with a flat tire on a newer dodge caravan. He didn't want me to get dirty but then i asked him if he wants to be stranded all night or get this done!?
Then I stopped at the love's gas station off the highway and a guy was there telling me he used to race a swinger 340 and wanted to check out my dart.
Then I got home and some people were on my porch. Jehovah witnesses, so it took awhile to get rid of them.
Busy day!!!!!
Flooring. Laminate. Hate it. Think the worst is over, battling the parts around door jambs.
And no more angle cuts.
Woner if i can get out of it tomorrow, want to start on rotisserie..
