They don’t say. I’ll watch the episode later todayWhat carb?
I asked to see some thongs. All I got!
Might get the Cuda trunk pan welded in today. Needs a bit more trimming. I was down hard yesterday and did not do anything. Have some distribs to do fast then maybe???Taking a break, already got the driver side inner cut out. Starting to fabricate cowl support. Gotta have a place for the inner to land on. Bowl of granola and a spot of green tea and I am ready to go again.
You can see what the field terminals connect to in this post: Alternator repair, a little show and tell.Did you see the thread I started about alternator guts?
Take a look. What Jaws posted about grounding one of the field terminals will make more sense when you see the innards.
Note the balance dimple.@Rainy Day Auto
here you can see where the brushes come through
The two copper rings on the rotor is what they contact.
When electricty flows through the rotor windings, it creates a magnetic field. That's why they are called field terminals.
Yes.Note the balance dimple.
