How does it sound running then?Hey Ray learned yesterday changing the spark plugs on the 383 especially #7 is challenging. It really sounds smooth now!!
Sounds really good...How does it sound running then?
Why??I have to drill holes in the wheel well housing at least on the right side next time the motor is out.
No it does not, brake cleaner or some fancy special stuff designed to get it off. I do not use it much anymore as a result.Does it come off pretty easy?
No busy yesterday. Probably take it out for a spin later today.Get on it yet to see how it moves at low rpm?
Super correct, had a read ahead would have saved me a response! Dang back reading!No, layout dye is permanent and hard to remove....
They have a special solvent to remove it...
Now that's funny right there!You forgot Carlisle?????
Which car or is it the truck??To get to the plugs in under half a day!
OK ya you definitely do these plug changes (383-440) on a cold engine.Dart with the 440
No idea.Any clue which mopar number plugs you would use? Have a bunch I am brining to Carlisle. For some reason got a bunch this year in lots of parts.
Well that’s good to know I guess. I’ll stick with scratch pencils and sharpies then. ThanksNo it does not, brake cleaner or some fancy special stuff designed to get it off. I do not use it much anymore as a result.
I will look them up. If I have a set I will throw them on the side. All nosNo idea.
We used dykem on the planes on occasion. MEK was about it that worked on that stuff.Well that’s good to know I guess. I’ll stick with scratch pencils and sharpies then. Thanks
Hey, you bringing any sun machines to Carlisle?We used dykem on the planes on occasion. MEK was about it that worked on that stuff.
I am sure I do I will send you a copy. Sold all the spares.Hey those Sun cards you have, when its handy look and see if you have the 67 Plymouth 383 280 hp one. If so I'll take it.
