I need to stop eating late, I am starting to get acid reflux when i eat and then sleep right after.I could go for an order of buffalo wings... I haven't had them in a while...
It's all downhill from here
I said "in awhile" not of all time.
I kinda don't like the sound effect on the mustang
Funny you say that because when I have milk, it's almost guaranteed to happenI found that eating some salad (lettuce) or have a glass of milk (sometimes chocolate) help calm my acid reflux....
I need to go through your small block threads with a fine tooth comb as I progress through this build
I am lovingly calling it "project greaseball"
What a grease ball
Have you tried soaking it in 'easy off' oven cleaner before power washing... I hear that stuff really cuts through the grease....
But wear a rain coat and goggles as that stuff can burn if it gets on your skin....
What a grease ball
I know oven cleaner really irritates the throat and feels like you're choking
Good to knowYou're not supposed to swallow, taste, or drink the oven cleaner, just spray it on the greasy parts and wash it off ....
I really want to get the car running before Halloween. That is my goal but who knows if I will get it because I am only getting a couple hours a week to work on carsFell free to go through them... If there's something you need to know and I haven't gotten to that part yet, give me a shout and I can walk you through it...
I just isolated a bunch of pictures for my next chapter on installing pistons, but have some duplicates of some and need to pick the best ones and weed the others out...
I can tell that this is going to be another long one...
I may wait until tomorrow and start it....
Some of them have taken 6 - 10 hours just to write, not to mention taking the pictures as I build and then sorting them out before writing the article... I put alot of time into them, I hope that it helps others so to make the time worth it.... It helps me feel better when they give me positive feedback after spending all of the time to make them...
I am learning the value of PPE, I used to use a lot of chemicals just like that. Aircraft stripper burns like a flame.
First thing to go are the exhaust manifolds.
What the heck was Chrysler thinking by casting a huge kink into the driver side. Yea real nice, doesn't even look right
Will these manifolds fit an early A??Pretty kinky... LOL!!!
They most likely had to put that kink in there to clear the steering and master cylinder...
That's not as bad as the early A-body with the 273 driver's side manifold... I may have to run one of those on my 66 Valiant wagon when I put the 318 in it... The wagon was originally a 170 three on the tree...
They are 74 dated, out of a 75 car
I would have to clear a z barI don't think so as the early A manifolds have more of a rearward twist than those... The only way to tell for sure is to test fit them in one with a v-8 in it...
I have had temptations to go v8 with my valiant wagon but I already have the mega rare slant six 4 speed bellhousing and I have a lot of money into the slant already.
A v8 seems exhausting but If these manifolds would fit then it would rekindle the temptation because it would be one less thing to have to buy
I swapped a 383 into a 67 notch years ago and it still had the original slant six drums. It stopped fine. I personally think some people make too much of a big *** deal about it. The most dangerous part of any car is the idiot behind the wheel.I have a few different styles of manifolds that I can try when I get around to dropping the 318 into the wagon...
But I have to find where I put the brake lines first and get them installed before I put the engine in... I'm converting it to dual reservoir... I have brand new 10" drums all the way around, but have a spare set of KH discs that I would like to put in... I'm still not sure if I want to change the brakes now or use the drums for a while and do the disc swap later since I already have the drums on and assembled...
