no, I haven'tSooo you call Ray^^^ about fishing???
when/where will this be?
I thought he bought it to flip it...? After the b'cuda I wouldn't expect him to get into a car build. But I didn't think this one needed anything.My SIL Picked it up to make a few bucks, he is impatient though....
Had a 10 second blip on our news this morning. And that was more of a thinly disguised jab at Trump...yeah and because its a flyover state, the main stream isn't covering it very much. A couple sentences here or there. They're estimating 14 million acres of corn and soybeans were destroyed. Iowa is one of the top 3 crop producing states in the US and the world for that matter, and thats not counting the number of crops lost when several grain bins and silos went with the wind. Given grocery prices were already thru the roof this year with covid, its gonna go up even more.
Hoppy and Mitch have the details, I am a mushroom, keeps me in the dark and feeds me ****!!no, I haven't
The delivery driver is always the last one told where to go...just sayin.Hoppy and Mitch have the details, I am a mushroom, keeps me in the dark and feeds me ****!!
Cant work on the mustang front end. There is a locking nut on each wheel,and key is mia.
Thinking about this, whos going to steal the wheels? They are more likely to take the whole car.
i set the whole day aside for this,and i figured it may go longer. I need to get it all done,as i have other work booked. In the meantime in fixing the drivers door latch, rod keeps popping off.
i sent Ray a PM, told him to add Keefer to the conversation....Sooo you call Ray^^^ about fishing???
On this?? I dont think so. Everything is new. I mean everything..I was able to get the locking lugs off our old Jeep by pounding a one size smaller socket on them and twisting the locking lugs off...
Get Er done
Yep. Trying tooGet Er done
Locking Lug nuts? If so, go get you a cheap 12 point socket that you won’t care about. Get one that just barely doesn’t go around the locking lug nut. Then take a hammer, bang it on tight, remove with impact, use a punch to tap out the locking nut and repeat as needed. Works everytimeStill no key for wheel locks. He found 1 but it was wrong. I can see myself welding a pipe to it to remove.
He does not want to screw up anything, even the lug nuts.....cannot blame him....Locking Lug nuts? If so, go get you a cheap 12 point socket that you won’t care about. Get one that just barely doesn’t go around the locking lug nut. Then take a hammer, bang it on tight, remove with impact, use a punch to tap out the locking nut and repeat as needed. Works everytime
It won’t. And it’ll cause far less damage than welding a pipe on the things.He does not want to screw up anything, even the lug nuts.....cannot blame him....
Nope. Been there. Only way to get a new key is if you have the card that came with the lugs with the key code on it. And you have to contact the manufacturerCan probably get the lock keys at Autozone or Oriellys
What I did was go to Discount tire, they have every key made....And bough a spare from them....EZ PZ!!!Nope. Been there. Only way to get a new key is if you have the card that came with the lugs with the key code on it. And you have to contact the manufacturer
Ain’t none of those around here. Just mom and pop tire places. That’s where I got the socket idea from years ago. It’s worked pretty well.What I did was go to Discount tire, they have every key made....And bough a spare from them....EZ PZ!!!
Mine are factory and I found an extra key at OreillysNope. Been there. Only way to get a new key is if you have the card that came with the lugs with the key code on it. And you have to contact the manufacturer
