My 64 reprint I actually got off or RA. It is fine in detail.
Holy crap, you are very fortunate you did not have a bigger problem.Lost power the other night around midnight, started generator which is in it's new shed. At 0330 I woke up and could see power was on, went out to shut it down. Output fan had failed and was melted, whole enclosure was hot, could have burned down the shop. I tested this set up, not sure what happened, two Lasko fans, plastic grate and blade, maybe need to get all metal or run exhaust out of container with RV pipe extension.
Surplus center has metal ones. I thought you did run the exhaust out? Get a extension somehow and wrap it with header wrap. You got lucky. I would add a simple temp switch to shut it down if it gets X hot. No idea what that would be.Lost power the other night around midnight, started generator which is in it's new shed. At 0330 I woke up and could see power was on, went out to shut it down. Output fan had failed and was melted, whole enclosure was hot, could have burned down the shop. I tested this set up, not sure what happened, two Lasko fans, plastic grate and blade, maybe need to get all metal or run exhaust out of container with RV pipe extension.
That's a deal.
I've got a reprint version... be nice to find an inexpensive original body manual. The repro I have does not have very high quality print and images
I read that also. There has to be more to the story than what they're telling.State Bill Could Save 1959 Chevy Corvette From The Crusher (msn.com)
Wow, pretty tough laws in Kansas.
Enough that I stay away from DNA tests and Ancestory.com. Sew your wild oats on Saturday night and pray for a crop failure on Sunday.My youth wasn't wasted. I was spent a lot by the end of the night.
I know car owners here in Kansas, that have had to replace missing VIN plates and have legally done so.
Yeah I got one right!Yes!
Well confusing actually. I’ll send a pm.
How's it going Chris?
Probably so but something's up I would think or there wouldn't be a bill going through? Seems nit picky, new rivets is the issue? Would think there's vin stamps elsewhere on the vehicle to verify with etc.
Yep. but what’s weird at least to me is the A body, there’s also a VIN stamped on the removable hood latch support. My Chargers did not have that.I removed the radiator core support on my duster, didn't know there was a stamped vin there.
I know that there’s a vin in the trunk gutter, there’s a vin on dash, on the core support and on a bodies, on the removable hood latch support. So where else is there a vin
only in some years, 68 and newer I think.Engine block
