It ran great in stock form. This cam/head change increased idle speed and now it pulls down in park. That is the biggest issue. Then the dirty run quality/tuning. I think the converter is too tight. We have one on order.
Gotcha. I am at 18° at idle and 36° with just mechanical. I had vacuum advance coming in very quickly. Between the added air bleeds (now increased from 0.125 to 0.136) and the removal of the vacuum advance, it runs amazing! Any rpm to WOT has no stumble at all, cruise is clean and still got 11mpg on a 7hr road trip.My latest is 22* at idle and 34* @ 3200 rpm coming in fairly slow. Didn’t graph it out on paper though. (Not yet anyway)
I used to think coverter effected idle but I don't anymore.It ran great in stock form. This cam/head change increased idle speed and now it pulls down in park. That is the biggest issue. Then the dirty run quality/tuning. I think the converter is too tight. We have one on order.
If you find the advance is begining at too low an rpm, need more initial spring force on the weights.It is a drop in GM style HEI distributor.
That comes with being old. My friend Mort (rip) had lots of great stories.Just disco the Speedo. And use a GPS for speed.
I actually have a funny story about being stopped in Kansas with the GPS Speedo.
Then again As I've often been told I have a story for every occasion.
OK we'll stop burning gas and let everyone enjoy their coffee.
About two cupsOnly 13.8 more pages to hit half million posts
How many tons of coffee did it take us to get here?
LS swap itMatt is doing it. I have no time right now. He is looking for one he feels bad since he sold it to us. I am sure it will be 1500 or so for sure. V6, 4200?
Ok LS swap it and welded a plate under the gas pedal so she can’t lolHell no she will total it like te two Aerocoups she had!
When I first got the Demon running with the cam in it, I needed to hold the brakes with both feet at a stop sign. It needed more idle speed than the converter would allow. I changed the converter and it was night and day with no other changes. Once that was solved, tuning could happen. I will try bumping the timing up, that is quick and easy. Thanks as always Matt!OK we'll stop burning gas and let everyone enjoy their coffee.
So epic closet fail this morning, and no I was not trying to come out of the closet, in fact I was going in? I walk in and uniforms are all in a pile on the floor, I am thinking WTF? Body armor was all on the ends by the wall so I know it was not overloaded as it was not even sagging. I dig thru the pile and find the closet rod busted at the seam, very cleanly. In fact upon closer inspection there is no glue in the joint. Factory closet rod QA fail!
The degree of knowledge and depth of understanding on this thread with zero emotional attachment is simply amazing. Whether Matt, or Hoppy or Toolman to just name a few. These guys can help you out if you actually listen and do not get emotionally attached to your solution.No No. Keep talking. I'm soaking it up
At our house, i do something stupid I always blame the dog. Jodi just shakes her head, not really sure if she believes me or not?The dog did it!
Sorry for your loss. I bet he had a ton of good stories.That comes with being old. My friend Mort (rip) had lots of great stories.
So true , lots of knowlegeable people on this site , not afraid to help you out! On that note good morning all , that was a 2 cup back read .The degree of knowledge and depth of understanding on this thread with zero emotional attachment is simply amazing. Whether Matt, or Hoppy or Toolman to just name a few. These guys can help you out if you actually listen and do not get emotionally attached to your solution.
That reminds me, I was looking at the Demons front sway bar the other day wondering if I put it on correctly, sure seems a bit low? Thinking I might should have put it above the hanger brace not under? I will get a pix and post.1 year ago today, I trashed my newly installed tie rod ends because I had the center link on upside down.
I have the front sway bar on mine. After you post a pic, i will need to check mine laterThat reminds me, I was looking at the Demons front sway bar the other day wondering if I put it on correctly, sure seems a bit low? Thinking I might should have put it above the hanger brace not under? I will get a pix and post.
