Work has a free app called Vessel View Mobile me and my boy use. Handy and has GPS speed in large numbers for a quick lookYup.. I use Waze. It will track speed and keep the phone screen active even without a destination plugged in
Hit most of the PA. Wine and Spirit storesI saw it inthe paper online . They targeted Walnut St Center City also. No idea if they came over the Schuylkill.
Could he use any speedometer housing and gear just not hook it up? May be the most secure wayIf not using it I would get something stronger like a rubber freeze out plug that will lock on there.
Waze has vehicle speed as well.Work has a free app called Vessel View Mobile me and my boy use. Handy and has GPS speed in large numbers for a quick look
That is what I was thinking...............I don't want to remove my old one, so it is with the trans when I sell it.Could he use any speedometer housing and gear just not hook it up? May be the most secure way
The monkeys are still slinging poop at each other
That will work. Make sure you change the inner and outer seal if it is a used housing.Could he use any speedometer housing and gear just not hook it up? May be the most secure way
I was wondering that also. Cant find a good picture.Is speedometer drive housing the same manual and auto? If so I likely have a spare Scott can have
after looking, getting housing will still be open though. The gear will not be in there and still let crud into it. Better off with a more substantial plug.That will work. Make sure you change the inner and outer seal if it is a used housing.
Do you have the factory spacer between the pump and pulley? Both my polys with iron pumps had a 1/4 inch spacer between the pulley and the flange of the water pump
Just figure out the thread ans screw in a plastic plug?The gear shaft closes the opening. Have to have it. See what passion uses. Be nice to have a lath to make a plug out of aluminum for this.
Hey Karl
Yes to all of the above
318 (1971)
Have an Early-A V8 radiator
Swapped in a cast iron water pump (driver side discharge)
Using the early timing chain cover with timing bracket (passenger side)
Water pump pulley is correct... seems the crank pulley I have is not
Vegas and Atlantic City.Hookers???
I believe they all have a clamp that holds them in. They don't screw it. Also, I do believe that the manual transmission ones are the same as the automatic transmission onesJust figure out the thread ans screw in a plastic plug?
Hey karl.That's what she said...
