Use a spacer on the master? Just a thought
huh - it looks like bringing it closer to you with an adapter won't do much
Work or Wife?
run from both lolThey are both four letter words....
I am just posting need therapy for it each morning I think!
I got lucky thanks to Tike!
Tell me about it! I had a hell of a time finding mine... .
it all seems so minor - until you dig in there and try to change it...I noted some changes I need to make when I drove the Swinger to Farmington and back. The seat/ wheel/ brake-gas pedals are all off for my liking. I have a stock 3 spoke wheel which is closer to me than I like. The flat rimblow wheel should be better when I get it redone. The seat is a flat bench that needs to be tipped backwards slightly and the original upholstery is starting to come apart. When I recover I'll have Joel replace the Jute with memory foam so that I will sink in when I set kind of like a bucket seat with the bolster sides if that's possible to do. The brake pedal is quite high off the floor. Too bad a shorter master cylinder rod couldn't be used to lower the pedal closer to the floor and still have enough stroke to stop the car. I might just leave it as is. Don't want to mess with safety! lol
That or morgan dollars or just bullion.American silver eagles?
side topic, anyone know of a place online to buy silver coins?
run from both lol
Karl how big is that box going to Anders now?
wow, that's the cheapest over spot I've seen thus far for silver rounds.
