Any of that western or Northern fire smoke making it your way?Air is so thick here you could cut it with a knife, and very foggy. Visibility on the way in was about 100yrds
Things are a bit red at dawn and dusk but not like the previous years. So - kinda maybeAny of that western or Northern fire smoke making it your way?
May need those rear pans, for sure need front floor in a couple areas[/URL]
[/URL]
ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3Ad36147e2-85af-4cec-a841-d1a325c787a5
[/URL]
[/URL]
[/URL]
so many comments so little time!
Emotional Support Pickle
Jumbo (11" x 6") crochet, extra soft, handmade emotional support picklewww.facebook.com
Don't know the answer to your question, closest thing I've experienced is changing daughters Jeep Cherokee from a closed sytem to an open system. It used to blow the lid off the coolant tank iircQuick question.... how to tell if a thermostat is a 2 way or 1 way? Like how to tell if it will puke coolant into a tank, then pull it back in as it cools vs just puke on the ground if overcoming cap pressure then be low on fluid?
The thermostat is the same. I think the caps are different. Got me thinking on that.Quick question.... how to tell if a thermostat is a 2 way or 1 way? Like how to tell if it will puke coolant into a tank, then pull it back in as it cools vs just puke on the ground if overcoming cap pressure then be low on fluid?
In todays world she may retire on that idea, unfortunately lol!so many comments so little time!
[/URL]
I meant to say cap...with the pressure spring. Oops. More coffee pleaseThe thermostat is the same. I think the caps are different. Got me thinking on that.
ahh.. i was like... i don't think the thermostat controls that But wasn't 100% sure...I meant to say cap...with the pressure spring. Oops. More coffee please
I wonder if that pickles name is Richard?
That things looks like it needs a support group of its own!!
