- Joined
- Mar 17, 2018
- Messages
- 17,153
- Reaction score
- 41,895
My view this morning! Great day to be alive!
Grasshoppers are the best! I went low brow with a Cub Cadet zero turn! But man once you go zero turn you will never go back.I found mine a couple years ago that a farmer inherited from his grandpa. It was five years old with 250 hours on it. I paid about your price for it but my buddy who has mowed yards for a living with one said I'd never have to buy another mower. It runs like a champ I grease and change the oil every 100 hours. My five acres has some steep elevation changes unlike the John Deere zero turn I use to have the Grasshopper handles it all with no fear of sliding sideways or roll over.
I have students this morning then on to Jodie’s truck. And you are correct Frank much like a carpenter who sees every problem as a nail for the hammer. My default setting is to solve anything metal with a welder! I can run a zip wheel on a four inch grinder like most people use a pencil!Morning!
Its cool again this morning, rain expected. Back on/under the 37 and see if i can power it up today. Then move it into shop,finish underside wiring.
Then some more yard clean up.
Now thats Ben Bait! @Ben DrinkinI prefer thigh high thursday
Nailed it!!!!Now thats Ben Bait! @Ben Drinkin
Calendar?Nailed it!!!!
I agree with once going zero turn you’d never go back. Had a 60 deck JDeere when we had the larger property and upgraded to a Kubota Diesel zero turn with a 72 inch deck. That machine was a beast. Once we downsized, that mower was way too large for this yard, traded it to my son for his Xmark zero turn 54 inch deck and is perfect for this smaller yard. The difference from tractor to zero turn is amazing. The time saved allows you to do other important things…Grasshoppers are the best! I went low brow with a Cub Cadet zero turn! But man once you go zero turn you will never go back.
No I screw mine.................................................to the wall!Calendar?
Unless you’re on a hill. Ive had trouble with zero turns on slopes. But they work great as long as you stay with the slope, its the slide if you try to turn to avoid things like trees that sucksI agree with once going zero turn you’d never go back. Had a 60 deck JDeere when we had the larger property and upgraded to a Kubota Diesel zero turn with a 72 inch deck. That machine was a beast. Once we downsized, that mower was way too large for this yard, traded it to my son for his Xmark zero turn 54 inch deck and is perfect for this smaller yard. The difference from tractor to zero turn is amazing. The time saved allows you to do other important things…
Speaking of, what’s the theme this go around for next years?Calendar?
@Petty Betty Has it now if she wants it?Speaking of, what’s the theme this go around for next years?
Thank you, I typically read this thread every day but just decided to jump in. I have noticed it can go any direction quicklyWelcome rowinafour. Wear a seat belt in here.
I would like to try one. We have a slight slope here that I mow diagonally. It is only a 4 or 5 foot rise in 15 feet and only 1 tree to mow around. It wouldn't be an issue I wouldn't think. I would miss the bagger that my rider has. You can get a bagger system for Zero's.Unless you’re on a hill. Ive had trouble with zero turns on slopes. But they work great as long as you stay with the slope, its the slide if you try to turn to avoid things like trees that sucks
Love your Avatar!I agree with once going zero turn you’d never go back. Had a 60 deck JDeere when we had the larger property and upgraded to a Kubota Diesel zero turn with a 72 inch deck. That machine was a beast. Once we downsized, that mower was way too large for this yard, traded it to my son for his Xmark zero turn 54 inch deck and is perfect for this smaller yard. The difference from tractor to zero turn is amazing. The time saved allows you to do other important things…
