Unconventional
ALEXIS --- Large Dunkin Midnight for everybunny
Before you order, pm me , I have some spare 10 percent off codes from power tour I won’t useFree Shipping on Orders Over $109 at Summit Racing
Will have to do some research and figure out which of these springs is better for me, ones I found on C list are NOT what was on my car the P3412003 and P3412002's were. Ones I had rated at 3200, one's for sale on Clist rated at 2800
Wow just wow, those look great!
Good parts and people! What more could a guy ask for?Sounds like you scored some good parts and made some good friends. Glad to help. Hope to meet you at Mopars in the Park next spring.
It's official.Good parts and people! What more could a guy ask for?
Is that my officially unofficial invitation to Mopars in the Park? Haha. Yes sir, I certainly hope to be there, and if the Mopar stars align maybe even with a little extra 3200lbs in tow? Hard to say but maintaining a positive attitude and looking forward to it, regardless! Thanks!
You gotta go! We lived in Fargo for years and never missed it. We went to Carlisle this year instead as we can’t make both. Both shows are just filled with great FABO folks and many you will meet are part of this eclectic coffee crew! And don’t believe nuthin they say about me if I ain’t there! Hah!Good parts and people! What more could a guy ask for?
With the window casing where it is Mike, I'd say remove the panel up to the height of the refrigerator and cap it with a piece of trim or something. The shelf would stabilize the top portion. Matching a cabinet might be a PITAWell we have appliances. Well, they are in the house any way. The frig cavity is a half inch too narrow and that has to be dealt with. The right side wall either needs to be removed or somehow moved out an inch. I need to work with the wife on that so it passes her inspection. If the opening is wider I can push the frig back an extra 2" and still have clearance behind for the waterline and ventilation. I might use ventilation as a selling point for removing the wall. The stove fit good and works well. Same with the dishwasher. I will need to install the dryer. The flexible vent tube needs replaced and I need to get a new flex gas line. The one I have is 25+ years old and is too short because the fitting is on the opposite side of the dryer. Always something but so far, so good. I will post a few pics to this post in a jiffy.
I wouldn't think so.Sooo. Leaving restaurant 66 exhibited a strange behavior. Put in 1st, nothing. Hmm. Had to give it gas reved up over 2 grand and slowly moved. Now shifts ok. Is this a function of the stall speed?
I put a vote in to remove wall altogether. Let it "breathe". Also, makes it easier to pull out and clean once or twice a year.With the window casing where it is Mike, I'd say remove the panel up to the height of the refrigerator and cap it with a piece of trim or something. The shelf would stabilize the top portion. Matching a cabinet might be a PITA
That'll avoid the footprint on the ceiling I'm guessing is there.
My thought is about what the impact on the ceiling is. Mine are all pattern textured, which you wouldn't be able to recreate.I put a vote in to remove wall altogether. Let it "breathe". Also, makes it easier to pull out and clean once or twice a year.
Omg I hope soI wouldn't think so.
Clutches were all ok? That you know ofOmg I hope so
@lkopaskaSooo. Leaving restaurant 66 exhibited a strange behavior. Put in 1st, nothing. Hmm. Had to give it gas reved up over 2 grand and slowly moved. Now shifts ok. Is this a function of the stall speed?
If it’s working, I’d leave it beDriving my 66 some. It seems like the line pressure is lower. Cheetah valve body was taken apart and cleaned. I bet the pressure was not set to Cheetah specs. Hmmmm
Isn’t that exact same thing what it did in Bowling Green?Sooo. Leaving restaurant 66 exhibited a strange behavior. Put in 1st, nothing. Hmm. Had to give it gas reved up over 2 grand and slowly moved. Now shifts ok. Is this a function of the stall speed?
