dukeboy440
Agreed .I wouldn't think so.
Ok that just takes the air right out of a guy.I have a feeling this transmission will have to come out again. Acts like low on fluid but it's not. 10 quarts...deep pan. Right on full on dip stick
Fuc brand new cheata valve body. But you might be right...Isn’t that exact same thing what it did in Bowling Green?
I’m wondering if it’s your valve body now
That's why I like the extra pedal option..I have a feeling this transmission will have to come out again. Acts like low on fluid but it's not. 10 quarts...deep pan. Right on full on dip stick
My thoughts exactly. We do have a cabinet that may fit that void above the frig. (made by the company that made the cabinets). Either way, that wall piece needs go get moved or removed. If we do, the frig can be slid back in the hole another 3 inches making it more counter depth and there will be some better ventilation back behind it which will be easier on the unit.With the window casing where it is Mike, I'd say remove the panel up to the height of the refrigerator and cap it with a piece of trim or something. The shelf would stabilize the top portion. Matching a cabinet might be a PITA
That'll avoid the footprint on the ceiling I'm guessing is there.
There is just a box for the frig. Above it is finished and wallpapered.My thought is about what the impact on the ceiling is. Mine are all pattern textured, which you wouldn't be able to recreate.
And most are made overseas with poor QC, wouldn’t surprise meFuc brand new cheata valve body. But you might be right...
Only common denominator is the valve bodyThat's why I like the extra pedal option..
To many mixed parts in the setup you have Tim.
Then that's just my unprofessional opinion.
Oak. I'll see if the cabinet fits before cutting anything. That will tell me what can be done.Cool
I'd lean toward a shelf across to support. You'll have the raw edge to deal with, which you could stain if it's solid wood, or put a piece of trim off it's press board, just to seal it up.
Other option would to be remove it all, then, if the wallpaper is just that strip, remove that bit of paper and the top board to go with a skim coat and and ceiling paint
Research cheetah valve bodies not cheap made overseas. Made in the USA. Premium. However it has been taken apart and cleaned. So who knows if it was assembled correctlyAnd most are made overseas with poor QC, wouldn’t surprise me
Adjustment is pretty easy, at least on a 727.Driving my 66 some. It seems like the line pressure is lower. Cheetah valve body was taken apart and cleaned. I bet the pressure was not set to Cheetah specs. Hmmmm
She's back from the ankle roll last night?WNBA game on at 7 central. View attachment 1716295979
It's brand new converter and just rebuild 904. Not even 20 miles on it....should be perfectAdjustment is pretty easy, at least on a 727.
Measuring not so easy. Got to find someone to let you use their lift.
I haven't been able to get those stars to line up
YepShe's back from the ankle roll last night?
Trans failed. Replaced with new rebuild. Used original cheetah valvebody. It was new. Failed trans less then 400 miles on it. Bought new PTC Converter. Got it put back together seemed ok. Shifted fineIts been a while so maybe I'm missing something. What's does either have to do with line pressure?
