How is the GTS coming along there Mitch? By the way Stan got a small 5pt yesterday. MMMMM venison for me!
I bet you are chomping at the bit to hear it run.
I hear you. Looks like I might get a lift in the spring from OMR. Excited to say the least.
Oh I know it. It was in the shop plan before I got sick. Should be fun to put up. I just hope they poured the concrete the way they were supposed to in the shop. I was in Kuwait when they did it. How thick do you need anyhow to bolt it down? I asked for 1' in a certain area but again I was not there for the pour of the floor. I do know they reinforced it with like a rebar 4x8 type of sheeting.
I was in the CAR and Chad and Mali at 105 deg temps working outside. What Celsius is that?
That's the plan!Easy enough to find out. Hammer drill and a long bit. You will know when you punch through it. Just use small dia and caulk them shut.
Way too many.
Mornin' Ters!
That's the plan!
So you're gonna find a hole and put some caulk in it?
