j par
Well-hung Member
More glory.....
Thank you!! I'm over the moon happy...
That looks awesome. Keep up the good work. It'll look great once done.
I want the world and I want it now!Good stuff J! Be "done" in no time at all!
Which way did you Orient your bushings for your transfer case? I ordered the two sets you recommended but I'm not sure if I should put the big puck on top and the small pup between the frame and the transfer case which makes sense in one way and then another way I think about more cushion between the frame and transfer case LOL? But it is hanging from the frame so having more cushion on the back side and more surface on the back side to hold it from falling through?.Looks excellent! Nice.
FYI, I had 3 new drive lines made for my ‘74 build.
1410 yokes/U-Joints, super HD splines, heavy wall seamless tubing. $1320.00 for all new shafts.
My plan was to run the exhaust over to the passenger side and out the passenger side before the back tire. I was hoping to run dual pipes out the side with quiet mufflers.. I don't want a loud truck.. I did get that screaming deal on the headers... Probably a couple of quiet mufflers...I’m curious how you’re gonna run your exhaust. Gas tank on the driver side, transfer case on the other side with a drive line in the way....LOL. I’m gonna attempt to cross over somehow from the headers, go 2 into 1 and use a small little dynonax race bullet and dump out the side of the bed or before the rear axle.
Yes that was pretty much the next thing I was thinking..Why not wait until you get the truck together and on the ground before you get the shaft cut.
Stash it in the corner and move on until near the end of the build.
