Acceptable carbs for the street
How many miles a year are you going to put on it?
I dunno yet. There are many variables such as: Will the local track be open and for how much longer; What is the weather like; Where do we choose to go in it; etc. I'm in the Pacific NW and don't plan on going to MATS or the Nationals with it; maybe a 50 mi radius?
What carbs are you more comfortable/experienced at tuning edlebrock holley etc.. ?
I buy a pair that you know well that are sized right.
I have dabbled with all of them and am confident I can get a good tune (AFR meters are your friend!) with whichever I choose but, if not, I know there is a wealth of knowledge here to help me sort it out.
The Carter and Edelbrock are dry flowed. I flow tested a 600 cfm AFB and it did just about dead bugs on exactly that.
Holley, as I understand it, wet flows there carbs.
Is there a difference somewhere in this?
IDK
IDK
Someone with a whole lot more experience and time than me should do a study/testing of wet vs dry, Carter vs Edelbrock vs Holley, 500 vs 600 vs 650 vs 750,... etc. Maybe it's been done and I'm just not aware of it? Probably deserves a thread of its own. Anyone?
I’ve done some work on the 600 AFB in modifications. Some still have to be tested. As far as I’m concerned, the airflow ratings are accurate.
Edelbrock Performer/Carter AFB's are good.
AVS/AVS2 are very good street carbs. I've used the AVS in the past with good results.
If you got the knowhow and resources the Carter Thermoquads are pretty good too, but unfortunately not much aftermarket support.
I really like the Street Demons. Been daily driving with them on my duster in rain, shine and snow since 2017.
I love TQs too but this is a Hemi cross ram and I want to stay close to original. If this was an inline situation, I'd have no problem mounting two TQs just to be different & to irriate the purists but I've got to keep this within the "look" of a LO23.
I got a pair of AFB's with my max when I got it. I'm almost positive they are 3705s, tho there is not a significant # on either one.
Chokes missing from mine, when I got em.
I read somewhere on one of the racer threads (not a Mopar thread, maybe yellow bullet?) where someone had done exactly that. I have no clue where I saw it, however. If faulty memory serves, wet flow seemed to be about 95%, roughly, of dry flow.
Edit: a Google search found it, on Speed Talk.
Good on ya! I'll look into it. Thanks.
I personally would call BLP get a couple billet 650s or 650 builder kits, ran on progressive linkage and 16 hole annual boosters.
Bring your engine over here to Yakima and let's Dyno tune it.
Will do. Now get off the computer & get that car done!
I would like to be more knowledgeable about fuel injection paired with a crossram manifold. I haven't done much exploration of this application, but as my Dart starts coming together I may get serious about doing so.
Rich Nedbal did a crossram multiport EFI conversion on a Hemi where he kept everything inside the manifold except the two throttle bodies. Page 87 in his book How To Build Max-Performance Hemi Engines (SA Design 164). However, this was the MP crossram with the two removable top plates. In talking with Rich, he says there isn't a way to do it (hide the injectors & wires, fuel lines, etc.) on the STR or single piece intakes. I s'pose you could do a dual throttle body deal that has the injectors in the throttle bodies like a Holley Sniper system, FiTech, or other company's product - that's where I was at until I decided to do it old school with carbs. PM me with any questions.
Most folks who run 'dual' four barrels forget the squirters need to halved.
An engine will take the air flow it needs but getting it right 'off closed throttle' is tricky.
Setting up the pump jets is where the magic is, once you get into the mid range life gets easier.
They used to say don't over-carb, now its 'the bigger the better' it seems.
Most engines will run with a 600cfm carb, so two 600's would be fine.
I've used two 750 Competition carbs together and they was good.
I'm sure a pair of AFB 625's would work on the street.
