excellent!
You have one kicking around and like the Crane H-272?
what do you expect your static compression ratio will be 9.5:1 or greater?
400 is possible with that small camshaft, using 1.6 rockers (.480/.510) and having the heads work well.
Intake tract is the make or break on this one for 400hp
Whoa that's kinda bad! I put the crank in and torque it all down with Plastigage; check the p-gage for clearance. If good, then torque the crank in again; if it spins free with an easy twist of the hand, then it is good. (Good enough that I have never had any issues or odd bearing wear).As far as main line hone, my machine shop did it for free on my first motor. After i got the short block together, i called them up and ask if it was normal for the torque wrench to go over 100 foot pound before the crank would start turning.
I took it back and they fix the problem. Not everyone needs one, but some need it REALLY BAD!!!!
if the crank dont spin easy still dont mean block needs line bored, could be a bent crank!! sposed to check line bore with a straight edge and feeler gauge's with caps torqued down, if it ant right,right it!! plasta gauge is ol skool,.dail bore calipers!!!Whoa that's kinda bad! I put the crank in and torque it all down with Plastigage; check the p-gage for clearance. If good, then torque the crank in again; if it spins free with an easy twist of the hand, then it is good. (Good enough that I have never had any issues or odd bearing wear).
If you wanna get weird with it, try a draw thru turbo setup:
Stock block
Stock low compression pistons
Stock heads
Stock 4bbl intake
Draw thru turbo adapters
Used turbo
Stock log style exhaust manifolds
Low duration truck cam
Universal wastegate
Use any carb!
Use an HEI 5 pin and ground the little pin via a relay and Hobbs switch at 4psi boost to retard ignition 10 degrees.
No intercooler
No blow off
No boost friendly carb
This is true but easily verified by putting a dial indicator on the #3 main journal and turning the crank. @Cudafever--if your crank truly needed 100 ft/lbs to turn I would want to know why. I would suspect a MAJOR problem like .010" bearings on a standard journal or worse--cracked main bolt holes allowing the bore to distort irreparably I might add. I use Plasti-gauge in a pinch but I have seen it tell me clearances are tight when they're not and tell me clearances are loose when they aren't. When direct measurements aren't available feel becomes VERY valuable. I don't really want to convolute this thread but this may become relevant when I lay the crank in and possibly encounter a problem. J.Rob
You are right; p-gage can show tight or loose if things are well bent or well out of alignment, and whether the tight or loose is on the side where the p-gage is placed. Maybe I just have been lucky with blocks....I use Plasti-gauge in a pinch but I have seen it tell me clearances are tight when they're not and tell me clearances are loose when they aren't. When direct measurements aren't available feel becomes VERY valuable.
A cheapie 360 build:
Basic (cheapest) machine work
Tanked
Bored
Honed (no plate)
Checked mains, they were good
Same ugly Pistons that you have
Decked to a true 9:1
Resized rods with new bolts
Isky mega 292 cam
273 rockers
235 CFM 587 heads
Eddy Performer
Much rubbed on 600 Holley.
OE dizzy w/MSD box
$99 headers
2.5 exhaust with parts store muffs
904 w/2500 converter
3.23 gears
3500 e body
255/60/15 Dunlop GT radials
13.43 @ 108 as driven.
Tanked
Bored
Honed (no plate)
Isky mega 292 cam
273 rockers
235 CFM 587 heads
Eddy Performer
OE dizzy w/MSD box
$99 headers
3.23 gears
3500 e body
I'll be interested to see what you do with heads on this, RAMM. That is the key....
What happened to the build you were doing with the SFT cam that you had for the EMC deal? Did it hit the back burner?
Sometimes thes steps are needed and unavoidable. Doing it now at his shop is of no cost and 100% avoidance prep.Just wondering, things like boring for oversized pistons, line honing, decking the block, roller tip rockers are all things that don't go along with a "cheepy" build. At least not in my budget.
I know you said you already had a bunch of stuff lying around, but machine shop time ain't cheap.
If it were a "No cost to you" issue, you would do it on every engine.
Not checking is nutz!
Checking and knowing it is out of wack and NOT doing anything about it makes the insane asylums look like a serious think tank.
Being to cheap to do anything about it, I can not come up with any descriptions on the insanity of it all.
Cheap builds are builds done right and once. Not over again and again.
How anybody here can take pot shots at RAMM for the machining work done to insure a properly done job is unbelievable.
While YOUR BLOCK may not need any of these steps, these steps taken by the builder should be seen as needed for this block.
