I am using Scat Icon forged 21cc dish forged, Scat cast stroker crank, Scat 6.123 I beam rods, .
60779 heads measured at 65 cc +/- 1 (putting old unclaimed show trophies to good use)
Edelbrock don't know jack about your combo. Your better off getting info here than asking them. Their information already had you going down the wrong path. The guys here straightened that out pretty darn quick for you.
I too will take the 40-50hp for less dollars. I have a fresh set of the 60779 heads ported that flow 300cfm on my parts shelf for 2 years now and I still have not used them. Eventually I will on something.
That is pretty good flow or a generous bench. MRL only got 280 out of mine.
To the OP, I have a spare set of gold colored rockers on shafts that you can buy for $50 shipped. 2 of the rockers look like they were run with the adjustments loose as it appears that the pushrods ate into the bottom of the rockers where the adjuster is. Shouldn't hurt anything. You will need to buy a hold down kit like the one Hughes sells.
Also, the best geometry article I have seen yet is:
http://www.hughesengines.com/Upload/productInstructions/LengthCheckerDec2012.pdf
The heads I will be using next were bot from MRL and had the springs I bought for the cam installed. I basically let Mike work out what I needed to copy a build he posted here including the cam and roller lifters (a 418 which also has the 20 cc dish pistons I have in the 416). Bot Hughes 1.6 rockers and sent them up to him to clearance. This worked out pretty good. Only thing I might have done different is pay to also have the rockers put on the shafts and the shafts installed on the complete heads, ready to install.
The OP got his money's worth of free advice from this forum on the chambers. Good catch.
Gee thanks for the shout out there, "only got". Remember your heads are NOT fully ported, Stage 2 ported. Stage 3 is considered full porting and costs a lot more. You will not be disappointed with the way your stroker runs when you get it all done. ;)
Yes, it really doesn't matter what the head flows if the engine can ony access 250cfm! Too many guys want fully ported (300+cfm) heads because they think the engine will use that extra flow...when most times it won't.
That's why I don't like the current offerings being done on cnc's. Your stuck with the larges highest flowing port whether you need it or not!
Mo-Par, why so little duration? That will be almost 10-1 and you could probably run 255* / 260* like the 60434 voodoo.
Hey, I plan on runnubg the 60404 voodoo cam in my 340 stroker. Mike from MRL suggested it to me as a nice cruising cam with lots of low and midrange torque. Although I was originally telling him I would be using 2.02 stock iron heads. But now with the closed chambered eddies, do you think I should rethink the cam? It is an automatic 727 with 355 gears and I was thinking of a TC with about 2400 RPM stall, so I will not be slipping when I am cruising on the highway at 70 MPH?
