You just need one of these...
What is amazing is that the guy shows a car that won't fire but the engine is turning over rapidly and he says the battery is dead!
Wow!! She left the headlights on?Morning men. So about 2pm yesterday my wife calls from work, "Help, my car wont start". So I drive 40 minutes, have a small Generator and a fast charger, 2017 Edge sport. Keyless ignition. . So, I get there, no way to unlock to car, the battery is dead and there is no key hole to unlock. Wait!! ye there is a key hole, you just have to pry off a cover on the door handle! There it is!! Next, she parked so close to the wall in front, can get the hood opened. AND cant get it out of gear with a dead battery. Sum *****!! Electric parking brake. O yea as soon as I opened the car, sure enough the headlight switch was on. Had to pull the damn thing back with a chain and my truck, dragging the tires, Get the hood opened, smooth from there. What a ***** all electric everything. Charged the Batt, checked the ALT, was fine.
thanks brother, i understand this, exactly as posted, was wondering if i can change it to volt meter without changing the looks, where the charge deflection on the right side could represent voltage NOW instead of amps and discharge represent something like less than 12.5 volts
I think there's some guys that have done it. You have to measyre how far the sweep is on the original gauge (90°?) and find a aftermarket gauge with the same sweep. I think pulling the needle off without damage is the hard part. Let me see if I can find a link.
They are inductors and capacitors, enough to start the car. Some build up charge off of a low battery (& wouldn’t work like you said) but some come with a battery as well.-should workThose are a joke if the batt is completely dead. No way they can supply the kind of amperage needed to start with flat Batt.
Well, I am in a charity golf tournament today, I hope I don't embarrass myself to much, Later, friends.
I like the idea of a shunt amp meter vice measuring ALL of the current flowing, but am ignorant at this level.Volts won't tell you how much you are charging as much as amps will.... I prefer amps to see how much my alternator is putting out...
However, I like to use both volts and amps to see what's happening in my electrical system....
Just gotta control your balls.
I better get busy..
I was sure they are for ‘instant jump’ ignition. The BIG (battery size) portable chargers charge the battery up.They are not designed to do an instant jump, they just allow you to slowly charge the battery and/or get enough power to operated the electrical systems like doors, etc.
And they do work to get enough power to start the car. My SRT battery was dead and I used ours to get enough charge back to start it. It took about 20 mins of connection before it fired up.
How can anything but glass give you infinite resistance in a circuit?Volt meters require infinite resistance to measure the volts, ammeters require 'zero' resistance to measure current flow accurately without adding to the resistance to get an accurate reading....
You learn that in circuits 101 when taking engineering (both mechanical and electrical engineering)....
I can. I love my wife, and she me, but she doesn't appreciate the mopar budget competing with her spending.
The wife walked around the house (where she had not for years) and discovered a second road runner (had been there for 7 months). Didn't have clue one about it. BOY did she come back hot and loaded! (the car cost me two $500 payments and replaced a bad runner i had purchased years ago.) I just said, "SURPRISE!"
I think I can stretch my wire another foot if I need to
And you can charge the Battery but no way you are going to jump start thru those small wires going to the power point. The charger I was using is a charger/starter. But you have a point, I could have got it out of gear and released the brake. got hood open then....Good thinking....
I'm outta here!
I hate that they have removed the key from the passenger door (cost saving... )....
When I wrecked my Impala, the driver's fender got pushed back and I could not open the driver's door... When I drove it home, the headlight stayed on (the other one was taken out n the accident) ... I had to unplug the headlight so it didn't drain my battery as with no way to unlock the door with a dead battery, I couldn't get in my car as the driver door was not an option... I couldn't open the hood as it was too damaged from the accident...
I hate cost reductions....
If you haven't noticed back around 2003, Chrysler removed the tint strip along the top of the windshield as a cost reduction...
I think that's total bs....
Space limitations and/or how a vehicle is parked can make using traditional jumper cables problematic. This device can be used in those situations.I would prefer to use jumper cables for quicker results...
I hope they count it as time served and being good while I was there, I served no Segregation time. Just in case I ever mess up in the future. LOLDid you get credit for time served????
I'm sure there is someone who can do that. Redfish might have a better idea about who would have that level of skill.thanks brother, i understand this, exactly as posted, was wondering if i can change it to volt meter without changing the looks, where the charge deflection on the right side could represent voltage NOW instead of amps and discharge represent something like less than 12.5 volts
