If there is a auto paint supply in the area they have it prob under 20 a can have not needed any in a few years. Actually like it better I cut down one inch HF throw away brushes to apply it.
Blocked by my Norton. Can you post a pic?Amazon.com: 3M Brushable Seam Sealer, 08656, 1 Quart, 946 mL (Packaging may Vary) : Home & Kitchen
Looking at this, look right? Thx.
When I retired, I had 480 hours comp time. The total you could keep falling every year unless you had 480 hours. I started saving it in the eary 80's making $15 an hour. I cashed it out in 2007 at $35 an hour. A nice investment plan.Smart move there! Just in time too sounds like.
Sounds like my wife. I told her it's like she is working 2 $50,000 a year jobs. (70+ hours a week)Time and a half.
Work one and a half times your normal hours, for half your normal pay.
In English?Think this is what I used
I finally pointed out to mine that she was eligible for retirement two years ago.Sounds like my wife. I told her it's like she is working 2 $50,000 a year jobs. (70+ hours a week)
Get a box of the 1" brushes from HF and cut them at least half down and see how it works, some times need less than that bristles. Love them throw aways. Cut on a angle for a corner etc. Think 50 are around $10 last time I bought them and acid brushes also work in tight spots, same thing cut them down.
Can you just extend the exaust and use a louver for air intake?I ordered a Suncast outdoor storage cabinet for my rollaround generator. It will be a project as I have to add ventilation, probably a grate/screen with two box fans, possibly an exhaust port.
I used the tubes...Okay so brushable works well, is it a one part and if so how long can you keep a can around if you don't use the entire contents?
Surplus Center sells a ton of different 12VDC and 110 VAC fans. I have bought alot of them from them, worth a look. Way cheaper than retain, usually a new take off part.I have to run power into the enclosure, probably will put a power strip in there for fans and will need the battery charger that keeps the gen battery topped off plugged in as well. Fortunately I have an outdoor 30 amp RV outlet (single phase) right near where the generator will be so I can use that with short PVC or conduit run.
