Frodee
Off center a bit
Yea you could it's not any different than hitting a target with your gun. Eye sight and a steady hand.I couldn't do what you do Fred. Breakage or not
Hah! I wish I knew that. We know that some guys could read a plug after 10 to 20 seconds at wide open throttle. My impression was two or three passes were better.How long should it be run in each of those rpm/speed brackets to accurately test the plugs?
With the distributor set as it is, wait til you can do a WOT pull or two in high gear at the track or a safe dyno.Right now it is a bit rich, at what rpm, not sure. All? I just don't want lean at cruise. Although 8 barrels of fuel at awaiting at every need for more input.
Reason is that the leaner mixtures burn slower. To fully take advantage of leaner highway mixes will need vacuum advance.With the distributor set as it is, wait til you can do a WOT pull or two in high gear at the track or a safe dyno.
I dunno Fred.Yea you could it's not any different than hitting a target with your gun. Eye sight and a steady hand.
Yes true pushing out a dent you have to push the surrounding metal down if it's a big dent.I dunno Fred.
Hitting metal with a hammer takes an understanding of how that metal moved will effect the surrounding metal. To me its like knowing how the metal will move together when welding but more so.
The shop manual is good on setting alignment but maybe not so much on what you're asking.Hate to be a pain for you guys but I am not good at adjusting the torsion bars on my Scamp. the upper control arms are adjusted as far out as they can go and was wondering if I raise the front end it ma
Start with this training system..Yea you could it's not any different than hitting a target with your gun. Eye sight and a steady hand.
Did it again.There's a couple of cheats that sometimes can be useful.
When the camber is set first, then for caster move only the rear adjuster in for more positive caster.
That will change the camber somewhat.
To finalize the camber, move both the front and rear adjuster the same amount. This will keep the caster pretty close to where you just set it.
Got it thanks that helps. I have a front end alignment at a shop in a couple days and knowing a bunch more helps me understand the read out.There's a couple of cheats that sometimes can be useful.
Thanks pictures makes it better.
Get the right hieght specs and measurement locations copied from a FSM for the year and model. Its rare for a shop to have those.Got it thanks that helps. I have a front end alignment at a shop in a couple days and knowing a bunch more helps me understand the read out.
If they go by the original Caster and Camber, those were for high crowned roads and cbias-ply or cross ply tires. If your roads are fairly flat, have them set both sides the same.
Tell 'em its a power steering car (even if it isn't) as those originally got more caster.
I think it would create tension.Would the SKOSH chart help or just create more confusion?
And I forgot to mention and sorry but I'm running a QA1 K member and upper and lower control arms.Get the right hieght specs and measurement locations copied from a FSM for the year and model. Its rare for a shop to have those.
100 mg up to 3 times/day. I took the one, may as well have been an m&m.How many milligrams. I have a script for 300mg 3 times a day.
Yep you will be a zombie.
Although you should be pain free.
Damn, sorry Frank was hoping you would get a good night sleep.100 mg up to 3 times/day. I took the one, may as well have been an m&m.
looks like a 61 or so Rambler American front suspension
