I would think that somebody in the past put 3/8 line from the tank to the engine compartment on it, since it has a Hemi in it.
That's a real pickup.
One tube is not factory. LOL.
Some did have a return line but I'm not aware of any with two pickups.
Typical arrangement is a short rubber hose connecting the fuel pickup to the fuel line.
Why was there a hose ?? I would not expect flex between the chassis and the tank but I'll trust Chrysler was smarter than me here.
If ther car is really stifferend up, maybe not needed???
As far as the socks go, I recall there are flexible ones like that and non collapsing ones
That should be overkill by two even with 2 carbs. If pushing through a big fram filter and a cool cans then the electric might be needed.There are hard lines connected to the tank side that then go to both pumps.
Till it felt right. LOLHow far down do you put the sock on the pickup tubes? Does it matter?
LOL, thanksTill it felt right. LOL
Maybe halfway - I don't remember. Look in the end, there's a stop - at least on the old ones there was.
Thanks, I will see when we get everything with the motor back together.That should be overkill by two even with 2 carbs. If pushing through a big fram filter and a cool cans then the electric might be needed.
Race fuel is often easier to get than AvGas. Whatever its tuned for, stick with it unless there is a good reason the engine would prefer a different formulation. I assume you will go someplace closer than Atco now.
Holley/Demon Carb stumble (posts 472 - 491) See in particular the sketches of Cudafever's system in post 485, and his tests (488-491) that show lower pressure allows more volume to the carb.
Sigh. Can't like that Mitch. Plumbing repairs like that not much fun. At least PVC isn't too expensive.Well, I guess he's got an excuse since his heritage is from Myanmar. " He " would be my last tenant. But, I would think a Lieutenant Colonel in the army should know better. Apparently stepped on the PVC tubing in the pool house and broke it. Then tried to seal it up with who knows what tape. LOL. Spent a few hours today fixing the issue for my new tenant. It would spray a shower everywhere inside the pool house when you were trying to run the pump. I removed the old automatic chlorinator since we never used it since the pool was new. No, I do not like plumbing any better than anybody else. Lol.
You may not like it, but you done purdy good at it!Well, I guess he's got an excuse since his heritage is from Myanmar. " He " would be my last tenant. But, I would think a Lieutenant Colonel in the army should know better. Apparently stepped on the PVC tubing in the pool house and broke it. Then tried to seal it up with who knows what tape. LOL. Spent a few hours today fixing the issue for my new tenant. It would spray a shower everywhere inside the pool house when you were trying to run the pump. I removed the old automatic chlorinator since we never used it since the pool was new. No, I do not like plumbing any better than anybody else. Lol.
Morning kind sir. Or should I say sparky. To early for riddlesMorning. The word of the day is Institution!
Do you know the names of the co creator's of the Riddler. Just useless information my brain seems to hold.35 years of institutionalized Batman
