The kids went home and I had just enough daylight to start the S6. It started ok, carb was out of adjustment and messed with me as it would quit running, but start right up. I noticed light blue smoke from the tailpipe, then as soon as oil pressure shot up, I uped the RPms and oil was coming from the rockers very well actually making a pretty good mess. I thought maybe the rockers were a little too quiet despite setting the rockers to the cam card specs. but I'll go with it. The engine shut off or I let it die, then a large gush came from the radiator, some went down the rocker area I was certain that maybe that wouldn't happen since I was running it without the thermostat~ I did have a squirrel cage fan blowing,. but the temp got up to only 140, I set the timing at 8 degrees before TDc with vacuum line disconnected. I'm a little disappointed, at least it's running and not making any crazy noises. I may drain about a quart of oil when cold to see if any water made its way into the engine from when it gushed.
I wanted to do more but Gary bugged me to call it an evening~~ so, I'll get back at it in the morning.
dne'
dne'
