Thanks for the tips and have to agree on the temp, seems I often end up with CRAZY smoking times. I can set this smokers temp and I also have monitoring, not the to your phone kind but a probe that cables outside the smoker to display. Will see what I have for rub, it's a Boston Butt, 5.3 pounds. I have an electric stand up, chips go under and you don't have to open the door to addThat was me... i ended up not getting any cause of lazy for a pork butt (i am assuming 7-9pounds?) Don't do low and slow... do 350 not 225.. you cannot tell the difference and even competition guys do this now, it will drop your cook time by a TON.. Slather in mustard or worstershire (worstershire will stain.. so wear gloves) you won't taste either but they hold the rub on (if you use rub) cover in rub.. Optional to put in the fridge for a few hours to let it penetrate a bit... get it on the smoker for 7-12 hours. Basically til the middle is 175-195 depending how tender you want it, i like to pull mine around 185 as they do keep cooking from risidual heat for awhile.
Let it cool and shred it. I shred in a big pan and add a bit more rub and mix it into the meat as i go...
If you havne't smoked much.. go watch some youtube vids on your smoker setup and basics... it's supposed to be fun, just enjoy
